Results 1 to 8 of 8
    Super Member Sizzle Chest's Avatar
    Apr 2011
    Naples, FL
    5,902
    What replacement backing plate?
    I smoked a backing plate today on my MKII 21. I see there are 2 different replacement backing plates.
    What one is better/should I get to replace my factory plate?
    Thanks!
    Rupes LHR 21ES 6 Inch Backing Plate
    Rupes 6 Inch Backing Plate - 21ES & Skorpio Polishers
    Scott Harle
    Autodermatology
    #autodermatology
    Super Member emmjay's Avatar
    Feb 2015
    Dubai, U.A.E
    848
    Re: What replacement backing plate?
    Quote Originally Posted by Sizzle Chest View Post
    Thanks!
    From what I read, only one of them works with the MkII right? That is the non Skorpio version.
    Feb 2016
    91
    It's my understanding that only 2 6" plates that will work are the 21es plate or a 21mark2 plate
    Super Member Dylan@RUPES's Avatar
    Oct 2015
    215
    If you want to replace the plate with the same factory installed (gray ring) part you want the 981.320N backing plate.
    If you want to replace the plate with the high engagement plate (blue ring) that was original to the ES tools you want the 981.321N backing plate.
    Both those part numbers will have the correct notch for the Mark II pin. Both are the 150mm (standard for the 21mm tools) size.
    Enjoy!
    Apr 2011
    Naples, FL
    5,902
    Quote Originally Posted by Dylan@RUPES View Post
    Enjoy!
    Thanks Dylan! That's what I needed! Appreciate it!
    Scott Harle
    Autodermatology
    #autodermatology
    Super Member LEDetailing's Avatar
    Jan 2016
    Wisconsin
    1,729
    Scott or Dylan,
    How long (hours of operation) should a backing plate last on 15mm or 21mm Mark II? Guessing the 21mm will go through plates faster? I noticed my 15 mm mark II was dry yesterday and lubed it up with dielectric grease. How often are you guys/gals lubricating the back plates?
    Oct 2015
    215
    Quote Originally Posted by LEDetailing View Post
    Scott or Dylan,
    In both situations its "as needed".
    The plates will last varying amounts of time depending on how they're used. Some people are really hard on them and can kill a plate inside a year, others go 3-4 years before ever looking tired. The biggest telling sign you need a replacement plate is its no longer flat on the face (edges are curling up from polishing curves or using heavy pressure) or the pads no longer adhere properly to the velcro hooks.
    As far as lube - if you start to notice black skids on the plate back or hear/smell any signs of excessive drag. I usually put a drop of dielectric grease on the plate every 4-5 uses and it keeps it good - probably doesn't need to be that often even, but thats just my personal routine.
    Apr 2011
    Naples, FL
    5,902
    ^^^^Excellent info!
    Scott Harle
    Autodermatology
    #autodermatology
  1. Replies: 25
    Last Post: 10-07-2021, 02:58 PM
  2. 3401 replacement backing plate - in stock soon?
    By Whitewater25 in forum Flex Polishers
    Last Post: 04-21-2020, 08:49 PM
  3. Replacement Backing Plate for GG 3"?
    By Setec Astronomy in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 11-11-2011, 04:31 PM
  4. Griots 6" backing plate VS. Lake Country's backing plate
    By ryanmcg1 in forum Product Reviews
    Last Post: 09-29-2011, 11:29 PM
  5. Flex 3401 Replacement Backing Plate
    By thrasher in forum Flex Polishers
    Last Post: 04-02-2009, 02:04 AM
