Re: Rupes Mini- pushing too hard or defective
Yep, probably pressure. I after buffing out two vehicles with the mini, and Duetto, no reasonable stalling issues with either. One was using Keramik with yellow foam, and the other with yellow microfiber.
Even when I used the 3401 I didn't apply much if any additional pressure to the machine. Same with the pc. I never got into the "15 lbs of pressure" thing. Reason being that I got better results letting the pad spin as freely as possible. The sweet spot for me was "just under free spin" on the PC, and "weight of the machine" on the 3401. I mimicked how I used to use the rotary with them.
That's how I knew the Rupes line was going to be a very natural transition for me, and it was. I couldn't be happier using their system.
One of the most overrated tools I've ever bought.
Mark II 21 is bad a** though!!!
So then...
You're saying if a person's interested in a 3"DA that the Griot's 3" is the better option considering the extra money saved?
Exactly! Let the machine do it's job. Pressure is highly overrated. Not too mention it finishes down much better with less pressure.
2019 Nissan Rogue SL
This was polished and finished out with my Rupes Mini. I have to respectfully disagree. It's been well worth the investment for me.
Wrapt, could it be user error? The mini is a very good polisher. It is by far the best 3 inch polisher on the market and is much better than using a PC as a 3 inch polisher. You should sell your Rupes mini, there are many detailers who could put it to good use.
Sold it a long time ago.
All good. Polishing complex concaves, curves or narrow areas and it will stall like a new stick driver. PE8 is a much better option.
I have not experienced any stalling issues with my Mini. I have a PE8 too and rarely reach for it, like never LOL. Too each their own.
I'm very used to forced rotation, so I'm probably more sensitive to stalling issues. I can adjust my technique, but I'd rather not. I end up reaching for my 3401 instead.
By Elger in forum Wool & Foam Buffing Pads
Last Post: 06-21-2016, 09:32 AM
By The Guz in forum Show N' Shine
Last Post: 05-21-2016, 07:46 AM
By rah28 in forum RUPES BigFoot Oribital Polishers
Last Post: 12-22-2015, 02:20 AM
Last Post: 11-13-2013, 12:57 PM
Last Post: 11-13-2013, 08:04 AM
