Re: Got a rotary for christmas
Thanks i will go also and pick some hood or panel to practice with the rotary. what compound should i use and pads.
Help here would be needed. I use only two types of pads, but Lake county pads are popular. For compound find M105 and M205.
Bill 1234
2004 audi a6 quattro (traded).
2015 Ford Escape 2.0l ecoboost 4WD
Originally Posted by Rsurfer
The reason the swirls came back, is because they never left your paint. The polishing oils hid them. It's important to do a solvent wipe down after polishing to get rid of the oils before applying a wax/sealant.
Not that it matters, but are you a female?
What an odd question! Lol!
Sorry i mean to practice with the rotary. Should i use M105 and M205 also.
Originally Posted by master detailer
You got a good buffer just need to use it more to get the hang of it.After some time you will be better and can do more with it.you may also what to get a pc to get it wright for now. Just use the pc after you buff with the rotary .
If you aren't doing paint correction as a source of income and are correcting, polishing, and protecting just your personal vehicles...You may never need to utilize the cutting power of a rotary. If you want a top notch DA that can correct almost anything but polish paint to a diamond sparkle, go with a rupes or a flex DA! With that being said I have 4 rotaries sitting on my shelf (2 are still BNIB)! I really only use them for heavy duty correction or wetsanding and buffing. Then I switch to a DA.
Wow those are really expensive i am only a student LOL.
can i use the rotary to cut(if necessary) and the pc to polish?
The harbor freight da is similar to the Griots garage da in size and power. A lot of people use the Griots with great results. The harbor freight on is within almost anyone's financial reach.
The dewalt is more than capable of finishing out really nicely. Search on here for Mike's threads on how to polish and jewel paint with a rotary. The chance of burning paint when jeweling, or even finish polishing is fairly small. You'll be running the buffer on the slowest speed as you do these steps.
Check out some videos to get a better feel for the techniques needed when using a rotary.
Sent from my SAMSUNG-SGH-I777 using AG Online
You can, but you need to know when and more importantly, how to properly use a rotary. With a DA, correction takes a bit more time but it's pretty much foolproof! My suggestion would be to grab a PC kit with pads and Meg's m105 and m205 and go to town! Roughly $199 for the whole shebang!
If you have the time, by all means....master the rotary! It's a skill not many possess! Do yourself a favor though...Practice correction on salvage parts until you are confident enough to use the rotary on your own paint! :-)
I also believe the 3M compound you used contains fillers. I'd go with Meguiars M105&M205. Some lake country ccs pads in a variety of colors. Lean more towards the soft ones.
Maybe get 2 orange, 2 white, 2 black, 1blue, and a red.
If you know how to use it then please do.
Just remember to finish with an ultra fine polish and a white pad.
The results using a rotary can be outstanding, more so than a DA but only if you follow through with the steps.
Work in small areas and make sure to work the product unti it's broken done.
I see people try to hurry the job when using a rotary only to get poor results.
I have my GG6 that I use most of the time but there are times I want that super looking finish that only a rotary can give me.
By tattooman in forum Auto Detailing 101
Last Post: 01-23-2019, 04:45 PM
Last Post: 08-20-2018, 08:00 AM
Last Post: 09-08-2015, 11:48 AM
By Qusai in forum Auto Detailing 101
Last Post: 10-24-2012, 04:59 PM
By ANeat in forum Show N' Shine
Last Post: 11-21-2010, 11:52 PM
