I like using the Lake Country Hydro Tech Pads. They come in three different kinds. Cyan for cutting, Tangerine for Polishing, and Crimson for Finishing/Jewelling and applying waxes/sealants. I have three sizes. 4", 5.5" and 6.5". The most versatile and useful size is 5.5", and although I could live without the 6.5" (doing large panels), I couldnt live without the 4" for smaller and tight areas.#
Also, if you are relatively new to rotary the smaller (4" and 5.5") pads will definitely be easier for you to handle and will help you get a better feeling of your Makita and improve your technique.#
As far as the Backing plates the 5" Flex foam HD is ideal for the 5.5" pass. For the 4" pads you. An use the LC flexible 3 3/4 backing plate. For the 6.5" I use the Chemical guys 6" Flex Backing plate.#
