Results 1 to 7 of 7
Thread: Air Polisher
    Super Member pfix's Avatar
    Jul 2010
    St. Louis MO.
    493
    Air Polisher
    I am looking for feedback on performance and also recommendations for a quality pneumatic mini polisher to use with 3 and 4 inch pads.
    Jul 2010
    St. Louis MO.
    493
    Re: Air Polisher
    Bump,
    I am curious if anyone has used any of the pneumatic mini DA's with 3" or 4" pads? How does the power compare the Metabo and Griots mini polishers?
    Jul 2010
    St. Charles, IL
    Re: Air Polisher
    I have the 3" mini poisher from Matco. I love the thing I just used it on a Land rover defender that had been off roading with a lot of branch scratches down the side in hard to reach spots. Took a little time but I couldnt have done it with out that mini buffer.
    Jul 2010
    St. Louis MO.
    493
    Re: Air Polisher
    Quote Originally Posted by ColorsDetailing View Post
    How is the rotational power? Is it sufficient to use a foam or microfiber pad with a compound?
    I just found this on Megs on-line forum
    Pistol Grip Mini Air Tools - Car Care Forums: Meguiar's Online
    AG, any idea when this will be available?
    Jul 2010
    St. Charles, IL
    Re: Air Polisher
    If you buy the kit it will come with a 3" wool, foam compounding, and a finishing pad. The power is adjustable on the amout of "air' you have going though the mini buffer. I do use a 3 step process with it. The panel does take a little time to "warm" up. It does not heat up the paint like a dewalt will (well eventually it will but not as fast). Like anything it just takes some experiance with and it is just another asset in your arsenal.
    Jul 2010
    St. Charles, IL
    Re: Air Polisher
    Also it will drain the air out of my 60 gallon tank pretty quick. so make sure you have an air compressor that can handle it. The meguires one says it uses less air.
    Jul 2010
    St. Louis MO.
    493
    Re: Air Polisher
    I am considering a Mini DA instead of of the Mini Griots or a smaller backing plate for my full size Griots. I have a single stage 5 H.P. 60 gal compressor that will run the mini DA but they use a lot of air and they can work the compressor pretty hard to keep up. I like the lower air consumption specs. of new Megs polisher and Michael Stoops reported there is no trade off on power with the reduced air consumption.
    I will probably wait a few months after the Megs tool is released to weigh out the user feedback before I make a purchase.
  1. Replies: 9
    Last Post: 12-04-2019, 07:35 PM
  2. Griot's BOSS G10 Pneumatic Polisher - Air powered 10mm dual action polisher!
    Last Post: 04-08-2018, 09:52 PM
  3. Replies: 0
    Last Post: 09-25-2017, 04:47 AM
  4. Replies: 0
    Last Post: 02-04-2016, 12:44 PM
  5. Griot's Garage Random Orbital 3' Polisher as primary polisher
    By torque1989 in forum Ask your detailing questions!
    Last Post: 07-01-2011, 10:11 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
