Re: Dynabrade random orbital polisher kit
Originally Posted by Shiny Lil Detlr
Dan, just keep in mind that this isn't a forced rotation DA like the Flex is, it's a free floating spindle assembly just like the PC/G110v2/GG6. The major difference/advantage is that it has a 3/4" stroke length as opposed to all the other tools' 5/16" stroke.
Also keep in mind that the Dynabrade adapter is pretty much only good with large pads; it doesn't lend itself to anything smaller than about 5.5"
That said, I still highly recommend it if you have lots of heavy correction work to do; I have been getting awesome results with it on a number of different projects.
I believe you have the earlier model #61374,from what I've read this model operates in a random orbital motion only like the PC/G110v2/GG6 yet the new Dynabrade #61379 or 61384 has a button to allow you to switch from just RO to RO With Forced Orbit Rotation like the Flex 3401!
Dan
I have the model with the button and it operates as a random DA and as a rotary when the mode is changed , not a forced random orbital as a Flex 3401 does. Works great on large surface areas such as pick-up trucks,vans and rv's.
I still love my dynabrade, like 2o2 said, when you push the button its rotary. I also love mine for any large area. I use my Porter Cable now mainly for the smaller areas, (I also use smaller pads on the Porter Cable)
Adam
Wonder what KB is doing? I bet something neat!
Just placed my order for one of these too.
Dan
Incorrect. I have the 61384, which has the "switch" you're referring to. I also have a Flex 3401.
The rotary mode of the Dynabrade is just that - a rotary mode: the pad is offset from the rotational axis, but it's not really "orbiting" in the same sense as it would be with the Flex. Two totally different concepts IMO.
OK now I am confused I researched this deal pretty good so I thought,anyways will the Dynabrade offer as much paint correction ability or even more when comparing to the Flex 3401?
Dan
While I can't say for sure since I've never used either (I probably shouldn't say anything, but I will anyway) I would say the torque of each machine is similar, but how it is applied is different.
My guess is the Flex has just a smidgeon of an advantage. Those comments are based on what I've read about each of the two.
Then again, you should seek advice of someone who owns both.
Dan
If we're referring to the "DA" function of the Dynabrade as compared to the Flex, I'd give the Flex a slight (and I do mean slight) edge, simply because it is impossible to stop the pad from rotating no matter how you use it (buffing with the edge of a pad, tons of pressure, etc. won't affect its gear-driven forced rotation). With the Dynabrade, you can still stall the rotation if you get too off-axis with the pad or put ridiculous pressure on it.
As far as the Dynabrade in "rotary" mode, that's literally what you're getting; it turns the polisher back into a rotary, with the only difference being your pad is now off center as it rotates. This is meant mainly for convenience so you don't have to constantly remove and install the adapter every time you want to use the machine for a different task.
I agree! I too thought that since I'd be using a rotary polisher with dynabrade, it'll be comparable to flex 3401 when I'm compounding or finish polishing! But the pad still used to stop on curved surfaces and when under pressure(in DA mode), no matter how fast the rotary was going(rpm)!
Now when I have the flex 3401, the forced orbital makes more sense. While polishing for the first time with 3401, I felt that familiar traveling of the rotary polisher.
Polishing on edges and small areas is wayyy easier now. With dynabrade and rotary on DA mode, I had to constantly adjust the position on panels to ensure that the pad was rotating at all times + with a standard rotary polisher and dynabrade attachment, the whole setup can be really heavy LOL!
One good thing about dynabrade is, you can attach smaller backing plates on it and use 4" pads to work on thin areas!! I still use the dynabrade for that as I only have a rotary polisher with dynabrade and flex 3401(cant use flex on thin panels due to big BP). PC and megs da polishers can take smaller BPs.
Its great when you've wetsanded the panel and are compounding, you can simply switch to DA mode for finishing!!
It works great on large flat panels as stated, but I like flex while working on curves! My car has many of those curves on almost all the panels except the roof!!
And yes, dynabrade attachment does have great correctional ability!! I have compounded and finish polished many panels that I had wetsanded to remove orange peel, with dynabrade and it worked exceptionally great!!
By Jersey John in forum How to Articles
Last Post: 03-02-2014, 05:47 PM
By Coopers ST in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 11-24-2013, 10:40 AM
By 2shiny in forum Rotary Buffers
Last Post: 06-03-2013, 10:50 AM
By Mike Phillips in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 09-09-2012, 02:26 AM
By torque1989 in forum Ask your detailing questions!
Last Post: 07-01-2011, 10:11 AM
