105 drying too fast?
So I was playing around with M105 and a wool pad the other day. This was a never before used pad by the way. Now I'm thinking that it was because the pad wasn't primed fully, but the 105 dried way too fast. I would spread it with the machine off, and then go right to correcting. By the time I got to a section, it was dry. This was a 2x2 foot area too. Any ideas on how to get a wool pad primed correctly?
SELF BANNED
Re: 105 drying too fast?
Do not spread it around, that is your main problem. The air from the pad spinning is making it dry to quickly. M105 is suppose to flash quickly, you just need to practice more. I was using it earlier today with a wool pad with no problems.
Are you using a PC? If so, I've found reducing my work area to a tad under 18" square, gives me a decent amount of working time. At least 4 passes.
Also, what size pads are you using?
Enrique - Amateur Detailer Extraordinaire
"Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content." - Durant
SELF BANNED
He has a rotary and is using a Megs wool pad. He just needs to practice more to get it down.
Ah, I see. It definitely has a learning curve. OP, I've heard some members like using a spritz of water to extend the working time. Maybe it's worth a try.
There wasn't any mention on what speed he is using it at either.Try laying down a bead on the part you want to correct and picking up the product that way .
A light (and I mean light) spritz of water on the wool pad helps.
Yeah, I'm using a wool pad and rotary at around 1500 rpm. I was spreading it around and that was my problem. The product was just sitting on the paint until I got to it and dried out. I'm just doing to put some on the pad next time and just start from there. This stuff is such a pain in the butt, but the results that can be achieved by it are worth the time it takes to learn.
Dana, I want to see some pictures of the Lambo!
Work a smaller section because if Tampa is anything like Stewart it's warm and I would even say hot around here.
Clean your pad often. Hate to beat the Pad Washer Drum but I can't say enough about how nice it is to pick up each new bead or strip of product with a clean pad.
Meguiar's recommends misting on some M34 if you want to use a wetting agent but I've used plain water and it works, like AeroCleanse posted, just spray on a little otherwise you'll run into a splatter problem.
Thanks for the reply Mike! I need to spend a lot of time with it this weekend.
By JHZR2 in forum Auto Detailing 101
Last Post: 09-22-2015, 02:31 PM
By dooger54 in forum Auto Detailing 101
Last Post: 09-23-2014, 05:57 PM
By Kinalyx in forum Auto Detailing 101
Last Post: 10-19-2012, 05:39 PM
By Thejoyofdriving in forum Auto Detailing 101
Last Post: 02-27-2011, 08:27 AM
By D in forum Auto Detailing 101
Last Post: 08-21-2007, 07:10 PM
