3m Wool Pads & Sip
Which wool pad from 3M do you guys use? Can I us the original backing plate with my Makita rotary? How well does menzerna SIP perform with wool pads or is Megs 105 better?
SELF BANNED
Re: 3m Wool Pads & Sip
I use the Super buff III pads which you do not need a backing plate for, they are double sided. You will need their adapter though. Sip and wool is not a very good combo, 105 and wool is a very nice combo for sure.
AR, can you just use the 105 or do you need to follow with 205 on a wool pad?
SELF BANNED
You can either follow it up with 105 on a white polishing pad or the same with 205. Then I always follow up with a finishing pad and polish. To me 205 just doesn't have the best final finish compared to UF, 85rd or Scholl's S40.
Cool thanks, sorry OP did not mean to thread jack.
Why is SIP and wool not a good combo - care to elaborate?
SELF BANNED
To me I have never found it to do much or finish down as nice as I would like it to. I find it is a polish that works very well with foam instead of wool. To me some polish are meant for wool and some are meant for foam and a very few really work with both.
I understand if you are doing a "one stepper" but if you are going to follow up with a finer polish then I dont understand. I mean a medium compound and a wool is not supposed to leave a lsp surface. SIP with a wool pad and high rpm is a great combo to remove medium swirls on a harder paint.
SELF BANNED
I know wool and sip is not going to be lsp ready. It is just not a good combo period. I can use a polish and a foam pad to remove medium swirls on a hard paint, this way I don't have to break out the wool and then final polish after that. Maybe you should try that and see if that would work for you.
Anyway, I can agree that SIP works wonderful with foam but also with wool, the only thing is it that wool cut faster but with a duller finish.
My favourite now is PO203S with a foamed wool for correction, or PO203S with a LC green pad. Nice cut and a great gloss.
Today I used the new compound from Menzerna,Powergloss S100. Have you tried it?
Last Post: 08-29-2012, 10:40 PM
Last Post: 06-22-2011, 07:13 PM
By 2011wahoo in forum Ask your detailing questions!
Last Post: 10-07-2009, 11:21 AM
By Bubbabuff in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 07-21-2009, 08:28 PM
By Old Pirate in forum Auto Detailing Tools and Accessories
Last Post: 01-03-2008, 04:45 AM
