Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Junior Member Buracho's Avatar
    Nov 2015
    56
    Looking to buy a Rotary. Question on constant speed maintainer function?
    Hey fello detailers Its been a while since I've posted. Anyway, I'm in the market for a rotary polisher. I've noticed that only top tier polishers have the constant speed maintainer function. My question is for you experienced guys out there what is the real world difference with ones with this function and ones that dont have it? Is it a deal breaker? Thanks for the help in advance as always
    Super Member Rsurfer's Avatar
    Jan 2007
    14,100
    Re: Looking to buy a Rotary. Question on constant speed maintainer function?
    Are you speaking about the speed dial which is normally 1-6? If so, I wouldn't want to polish without it. Also a must have is a variable locking trigger.
  3. Likes PaulMys liked this post
  4. #3
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    If you are talking about the trigger lock, my advice would be: DO NOT buy a machine without one.
    I do not use a rotary on vehicles, but I have hundreds and hundreds of hours of time on them in the marine industry.
    Like Ron said above, trigger lock is a MUST have.
  5. #4
    Aug 2006
    I think what he is referring to is the machine being able to maintain the speed setting when you apply a load to the machine. Say you set it for 900 RPM and you put a load on the machine it will maintain the 900 RPM setting. I could see this feature useful when grinding and pushing down on the material. I have never used a rotary for polishing but I don't think you would be applying the same amount of down force when polishing as you do when grinding that would slow it down enough to notice.
  6. Likes Buracho liked this post
  7. #5
    Nov 2015
    56
    Correct. I apologise if i wasn't clear enough. I'm talking about when polishing when you apply down ward pressure to the machine it doesn't bog down and the RPM remains constant. BTW547 Got it right.
    So is it absolutely necessary to have this function in a rotary polisher or its just something high end polishers just have built in? Thanks guys.
  8. #6
    Jan 2007
    14,100
    Quote Originally Posted by Buracho View Post
    Aren't all rotaries gear driven and thus does not have the ability to slow down with a load? A clutch would accomplish this, but I don't know of any rotaries that have this and if even needed.
  9. #7
    Aug 2010
    New Jersey
    15,278
    Of course you can slow the motor down under load. Here's something I copied from the Flex PE-14 specs: "No-load speed: 380-2100 rpm". If the load didn't affect the speed, it would just say "speed"
  10. Likes Buracho liked this post
  11. #8
    Jan 2007
    14,100
    Aren't all speed settings based on "no load"?
  12. #9
    Aug 2010
    New Jersey
    15,278
    I don't know where you're going with this, if you load a motor up, it slows down. When you say it's "gear driven so it doesn't have the ability to slow down", that's like saying if you have a manual trans car and you step on the brakes the engine won't stall.
  13. #10
    Nov 2015
    56
    Yes so Makita and Dewalt rotary machines state that in their product descriptions. Each manufacturer has a different name for it. Makita calls it constant speed control and Dewalt calls it "Electronic module maintains specified speed under load" so its definitely a phenomenon. But my question here remains, is it a mandatory function for paint correction?
  1. 3D Speed w/Rotary
    By xabo in forum Ask your detailing questions!
    Last Post: 04-15-2023, 12:47 PM
  2. Klaase HG in maintainer?
    By mixdemotionsfox in forum Auto Detailing 101
    Last Post: 04-09-2020, 09:03 PM
  3. Mytee system maintainer
    By Mercedes350 in forum Ask your detailing questions!
    Last Post: 08-07-2013, 09:22 PM
  4. Newbie has a question. Already tried the search function.
    By Mambwe in forum Auto Detailing 101
    Last Post: 09-21-2012, 03:38 PM
  5. constant pressure pad colour question
    By embolism in forum Auto Detailing 101
    Last Post: 06-27-2011, 01:18 PM
Members who have read this thread: 36
