Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Newbie Member
    Join Date
    Mar 2019
    Posts
    8
    Post Thanks / Like
    What am I looking for ? Rotary or orbital or flex?
    This world is semi new to me, I have a 7424 DA but to correct severe glass scratches, I read that rotary is the way to go. All 3 cars are really bad, I need to clean and remove severe micro scratches. Its one of those that are not visible in day light but night time gets annoying. I had use cerium oxide with the glass polishing pad on the 7424 but it seem to take a log time. So I figure its time to invest in something new. From a few threads it seems like I need a rotary buffer, I also read this new flex might be good too. Any suggestions ?
    I'm not looking to spend too much, but want to get the job done. I have some griots 6" and some 5" glass polishing pads left (new). So like to get something that fits them.
    Thanks for any tip
    -Roranji
  2. #2
    Super Member Hermes1's Avatar
    Join Date
    Sep 2014
    Location
    Nomad, wherever we park our rig
    Posts
    255
    Post Thanks / Like
    Re: What am I looking for ? Rotary or orbital or flex?
    You say this is new to you, so I would either consider not using a rotary or get a body & glass panel from a junk yard to learn and practice on before working on your vehicles, because in inexperienced hands things can go very bad with a rotary machine very quickly. A better choice and If it were me, I would start with your DA and an aggressive pad first, that may be all you need. Always start with least aggressive solutions first and then move up as necessary.
    Sincerely, Bruce
    2015 Ram Big Horn CC 3500 Cummins DRW w/AISIN tranny
  3. #3
    Newbie Member
    Join Date
    Mar 2019
    Posts
    8
    Post Thanks / Like
    I only asked because I tried the DA for about a few hrs, and it didn't seem to make a difference on my test car. I have a 94 honda civic to practice rotary on. its so old, and all broken and its just in the driveway doing nothing. Worse case I can replace all the windshields. I dont want to go that route because of calibration issues with non oem glass, insurance always want to cheap out first, but if all else fails, I have that option.
    I replace windshields before but the issue with glass slowly comes back, so eventually Ill need to polish/clean it
  4. #4
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,098
    Post Thanks / Like
    4
    Quote Originally Posted by rsutoratosu View Post
    Get a cheap rotary from HF. You don't need a $300 machine to polish glass that may never have to be polished again.
  5. #5
    Mike Phillips
    Guest
    You need a glass polish with Cerium Oxide.
    I teach glass polishing. One of my rules is,
    If a company makes a cerium oxide glass polish and the pads to go with them - buy them.
    Don’t mix and match pads and products. Griots makes pads and a glass polish but it’s not a cerium oxide polish.
    Check out CarPro pads and Ceriglas glad polish.
  6. #6
    Newbie Member
    Join Date
    Mar 2019
    Posts
    8
    Post Thanks / Like
    Quote Originally Posted by Mike Phillips View Post
    thanks. Ceriglass I been using. By hand. I think I’m gone through 3 bottles since 2011
    ill get the carpro pads when I pick up my rotary. I been having this issue since 1999. End up switching cars and not bother.
    I now want to fix it and keep the cars
    if I get rotary from HF. Any speed range I need to pick up ?
  7. #7
    Join Date
    Jan 2007
    Posts
    14,098
    Post Thanks / Like
    1200 rpm should be fast enough. Caution, polishing glass with a rotary can get messy. You need to keep the glass moist with a spray bottle which in turn will create splatter.
    Mike P recommends a beach blanket to cover your wiper cowl and hood to catch the splatter. Ceri glass is water soluble which should clean up rather easily.
    Polishing glass is messy and time consuming. Do small sections and take your time.
  8. #8
    Newbie Member
    Join Date
    Mar 2019
    Posts
    8
    Post Thanks / Like
    These are the blotches i'm trying to remove.. so far nothing really gets rid of them, I used No Touch GS8 Auto Glass Stripper, it gets rid of some but not completely. So mechanically is the way to try next.
    What am I looking for ?  Rotary or orbital or flex?-wind01-jpg
  9. #9
    Newbie Member
    Join Date
    Mar 2019
    Posts
    8
    Post Thanks / Like
    Ok, I only found 5" carpro pads.. I assume I need a 5" rotary backing ? didn't search hard enough, HF seem to only have 7" rotary.. ill try looking again
  10. #10
    Join Date
    Jan 2007
    Posts
    14,098
    Post Thanks / Like
    It's the backing plate that is 7". The spindle is 5/8", so a 5" backing plate with a 5/8 female fitting will work.
    And yes Car Pro's rayon pads only comes in 3" (odd size) and 51/4" sizes.
  11. Thanks rsutoratosu thanked for this post
Similar Threads
  1. NEW Cordless FLEX Tools at Autogeek Rotary and Orbital Polishers
    By Mike Phillips in forum How to articles
    Last Post: 02-25-2019, 08:56 AM
  2. Review: FLEX XFE 7-12 80 aka The FLEX 3" 12mm Long Stroke Orbital Mini Polisher
    By Mike Phillips in forum Product Reviews by Mike Phillips
    Last Post: 07-30-2018, 01:38 PM
  3. Replies: 18
    Last Post: 06-01-2017, 02:26 AM
  4. Replies: 9
    Last Post: 02-15-2017, 06:24 PM
  5. Replies: 5
    Last Post: 06-03-2013, 10:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
