Results 1 to 6 of 6
Thread: Lake country
    May 2016
    jacksonville n.c.
    250
    Lake country
    Will 6.5 inch LC pads work on a 5 inch LC backing plate or are they too big? Probably gonna be ccs pads
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,017
    Re: Lake country
    I've seen people use that set up, but you're giving up a lot of pressure around the edges. I've tried it and it was very uncomfortable.
    Obviously, if you can pick up 5.5" pads, or a 6" plate, you'd be better off.
    Super Member Crispy's Avatar
    Jun 2013
    779
    Re: Lake country
    Backing Plates should be 1/2" smaller at most on normal foam pads. If it is too small and the pad is say 1" thick then there is a lot of pad distortion which increases heat and risk of the backing plate hitting the paint. Would you use a 6.5" backing plate on a 5" pad (of course not).
    Dec 2010
    91
    Re: Lake country
    Yes you can but it isn't the optimal setup like what the rest mentioned. Doing so would cause too much stress on the center and does little correction at the edges. Of course you can adjust your technique and swap pad often to get it work for you but a pad larger than plate by 0.1 to 0.5 inch is still preferred, at least for me.
    Super Member VISITOR's Avatar
    May 2007
    9,740
    Re: Lake country
    if you use the 5'' DA backing plate with 6.5" pads the outer edge around the backing plate will start to mushroom (cookie cutter effect) in over time when you apply pressure. use the correct backing plate with the appropriate pads. 5" DA backing plate = 5.5" pads / 6" DA backing plate = 6.5" pads
    i am the jump starter.
    May 2016
    jacksonville n.c.
    250
    Re: Lake country
    Quote Originally Posted by Crispy View Post
    Obv a 6.5 inch plate wouldn't work on a 5 inch pad. Wasn't sure about the other way around. Thanks for the info everyone
  1. Replies: 28
    Last Post: 02-26-2022, 08:11 AM
  2. Lake Country Pad help!
    Last Post: 04-25-2015, 01:06 AM
  3. lake country or ?
    By chachi94 in forum Auto Detailing 101
    Last Post: 02-11-2015, 11:26 PM
  4. Which Lake Country Pad?
    By mdgrwl in forum Auto Detailing 101
    Last Post: 02-24-2014, 10:22 AM
  5. According to Lake Country...
    Last Post: 02-05-2010, 01:10 PM
