Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 72
    Nov 2015
    Los Angeles, California
    13,781
    Re: help decide swirl/cut and polish for Z06
    Good luck getting much correction with black wax on the corvette hard clear. If you want to fill the swirls, by all means...
    Reason I suggested that is because he's just starting out [1st post, looking to buy DA & pads for the 1st time] so his wash & drying technique may or may not be quite on point yet.. It wouldn't be so great if he focused on correcting his paint, only to induce swirls right back into it due to the learning process we've all been through. We're not all born with our favorite choice of towels & mitts the 1st day😉
    Fillers allow you a mulligan while still being able to use your polisher for the 1st time.
    Sep 2015
    6,281
    Quote Originally Posted by Swirlbuster View Post
    SO>>>>>
    I have a BLACK z06 I want to improve.
    I have a 7424xp. Ive been told to get the 5"back with 5.5 ccs pads (not sure what colors I need yet)
    What swirl and polish combo should I go with?
    I've been told wolf gang works great but man it some pretty pricey stuff.
    I'm pretty sure i will go with this for my sealant Meguiars Ultimate Liquid Wax, polymer wax, best car wax, Ultimate Wax
    Corvette paint is a really hard paint to pull swirls out of .whats your definition of improvement,a correction or a quick Job.all those waxes you mentioned will conceal all the imperfections in the paint one wash you will be back to square one.
  3. #13
    Nov 2015
    13,781
    Quote Originally Posted by GSKR View Post
    I'm not saying you're wrong, because you may just be right.. But I would think it would make it past at least 1 wash.
    Ever since last weekend I've been looking for a guineua pig black vehicle that's loaded with swirls to run some tests on.. I'm interested in how long it lasts, and what it all looks like once the make up comes off. I plan to do at least 1 50/50 with the Black Wax topped with D156, and the other side topped with sealant, and maybe even another panel on it's own.
    1 thing I know is it doesn't last too long on it's own. But I've never witnessed how fast the swirls all come back because I've never applied to a car with swirls until last weekend. Lol.
  4. #14
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,017
    Quote Originally Posted by WaxMaster1 View Post
    If the Meguiar's Ultimate Liquid Wax is your LSP, just stick with their Ultimate Compound and Ultimate Polish. Can't really go wrong.
    Iike these even more than the high dollar boutique lines. Easy to use, readily available, and delivers great results consistently. Their "wetter" consistency allows for maximum pad rotation, opposed to being slowed down the way a thicker product will do. M100/M205 is what I use in their professional lines.
    If you stay with the CCS pad line, look into the pink to compound with, and green CCS to polish with. These pads rely on the cell construction to cut rather than density. This allows you to obtain maximum backing plate rotation, while using much less downward pressure.
  5. #15
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Just curious: What year is the ZO6?
    First things first...
    IMO: To determine the tools, pads,
    liquids, etc. to use for Paint Correction,
    certain steps/processes should be taken.
    So...
    After washing the vehicle,
    have you performed:
    •Iron particles decontamination (ex: IronX)
    •"The Baggie Test"
    •Claying (per: "The Baggie Test" results)
    •Diagnosed the "paint's condition",
    via Swirl Finder-lighting
  6. #16
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    SO>>>>>
    Wolfgang is perfect for GM paint .... as is Menzerna. You spent the $$ on Corvette versus a Chevette, don't skimp on the polish.
    Scott
  7. #17
    Feb 2016
    50
    So...
    have you performed:
    •"The Baggie Test"
    was planning on using this a my clay bar method
    Its called chadwick's triple play. one step uses a rubber sponge acts the same way the clay bar works.
    along with the bag test
  8. #18
    Dec 2010
    Ohio, USA
    21,057
    Thanks for the information.
    "Best of Luck" with:
    Chadwick's Triple Play Car Care System.
  9. #19
    Sep 2015
    6,281
    I just acquired a small exclusive used corvette dealer,and do about 8 to 15 vetted a month ranging in years from 99 to 2014 and I'm sorry I did pita.
  10. #20
    Sep 2015
    6,281
    Those sponges work great,but check them often for grit stuck in the rubber part.
  1. help me decide what polish to do today :)
    By ccapital83 in forum Auto Detailing 101
    Last Post: 05-09-2015, 11:14 AM
  2. help me decide what polish to do today :)
    Last Post: 05-05-2015, 12:06 PM
  3. Pure Polish after polish/swirl removal
    Last Post: 04-20-2012, 01:36 AM
  4. Trying to decide on a swirl remover
    By bus3 in forum Auto Detailing 101
    Last Post: 07-19-2011, 01:29 PM
  5. Cant decide on polish
    By Quattro3.2 in forum Ask your detailing questions!
    Last Post: 07-28-2010, 05:29 PM
