Would there be any issues with spraying the car down with TRIX after a rinse if it is hot outside?
Originally Posted by BrianJM Would there be any issues with spraying the car down with TRIX after a rinse if it is hot outside? The only possible issue is you would be diluting the TriX, and possibly not yield desired results. That process should not hurt anything else.
Detailing is a way of life, not a hobby!
I have seen that there is an iron x product that is basically a foaming wash solution, that acts as you wash with it. Is this effective? Sent from my LG-D800 using Tapatalk
Trix can stain plastic. Be careful.
'03 Corvette Z06
Originally Posted by mwemaxxowner I have seen that there is an iron x product that is basically a foaming wash solution, that acts as you wash with it. Is this effective? Sent from my LG-D800 using Tapatalk The IronX snow soap is an excellent paint cleaner. It will not dissolve ferrous iron like IronX. It is the soap I use before any paint correction work (in conjunction With IronX), or applying a fresh coat of protection to my personal vehicles.
But it still isn't a substitute for ironx I take it? Sent from my LG-D800 using Tapatalk
Originally Posted by mwemaxxowner But it still isn't a substitute for ironx I take it? Sent from my LG-D800 using Tapatalk It will still dissolve ferrous particles, but not as much as IronX. Equal substitute? No.
Is it foam cannon-able? Sent from my SM-T230NU using Tapatalk
Originally Posted by mwemaxxowner Is it foam cannon-able? Sent from my SM-T230NU using Tapatalk Nope.
Originally Posted by WRAPT C5Z06 Nope. Originally Posted by mwemaxxowner Is it foam cannon-able? Sent from my SM-T230NU using Tapatalk You can use it in a foam cannon, and a great one at that. In the name "Snow Soap" I use 4oz to a bottle. Rather foam over the IronX and spread with my mitt. It aids in not letting IronX dry, there is no way I would use that stuff indoors.
