Re: Which coating will fill the Opti-Coat 2.0 void?
Originally Posted by FUNX725
IMO: None!!
-Will there ever be another "permanent Coating",
in the same vein as OC 2.0?
-I'll say: No!
Opti Coat Pro!
Originally Posted by BlueBeast14GT
my fiance would kill me for spending all of our wedding money on paint coatings.
You should be registered at AG.
HOLY CRAP. YES!
So...Let me get this straight:
^^^Not OK?^^^
^^^Is OK?^^^
He made a valid comment about the longevity of a product. You just said nothing would ever live up to Opti-coat 2.0.
Other day I was reading about coating and this is what I found...
Opticoat vs. GTechniq C1
Originally Posted by Swift
Very informative! Thanks!
Great read! Glad I stocked up on Opti-Coat 2.0
Originally Posted by Rsurfer
Opti Coat Pro!
^^^That's Wrong...^^^
OC Pro is no longer a "permanent" Coating!
_________________________________________________
As usual: you misinterpreted/misquoted
another one of my posts.
Some misinformation in that thread and I'm not even done reading...
Opti-Coat does not add or subtract gloss, nor does it alter the colour or depth of paint. Which is why it can be used on matte surfaces also (wheels, raw carbon etc).
What changes the look is the paint correction as lovecolt says above. The idea is that the paint correction is performed to remove/minimise swirls and marring as well as increase clarity and gloss in the paint itself. The Opti-Coat is then simply used to "lock-in" that paint correction work. Once done it will then stay that way. As was mentioned above, Brad's car is a good example of this.
The above in bold is false. It does add a subtle darkening to the surface and this is can clearly be seen on solid black paint or even a matt finish by simply doing a 50/50 test section with a hard line.
MANY installers have reported etching from bird poo, which does not always just go away over time. I just had to do a touch up on car and the bird poo stain was given over 6 months to "go away" on its own.
[QUOTE=FUNX725;1170164]^^^That's Wrong...^^^
5+ years is permanent enough for me.
[quote=Rsurfer;1170184]
Your prerogative to use 5 years as your benchmark for permanency.
It's just not mine.
Last Post: 04-15-2019, 10:46 AM
By tpr1634 in forum Auto Detailing 101
Last Post: 03-19-2017, 11:59 PM
By Vrtcl in forum Tricks, Tips and Techniques
Last Post: 03-24-2015, 08:30 PM
By Sherif in forum Auto Detailing 101
Last Post: 10-24-2014, 06:46 AM
By olenderc in forum Auto Detailing 101
Last Post: 06-20-2014, 10:31 AM
