Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. #31
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Re: Quick review Meg D151 vs HD Speed
    Quote Originally Posted by Dellinger View Post
    Calendyr,
    Interesting feedback regarding your experiences with 151/ Speed.
    I have had the exact opposite findings.
    With D151...
    I had tremendous dusting on a 2004 GMC Yukon, beige metallic. Barely got 3 section passes with heavy pressure, fast arm speed and small sections (18"x18".) Was using a traditional D/A (PC style) speed set to 6, 5.5" B&S orange pad, non-primed. It could have been the paint (severely neglected with the owner admitting that he had never waxed the vehicle in his 6+ years of ownership) sucking in the liquid. I had to use 2 pads per panel because the pad was just saturated from 151. I couldn't dial it in and have yet to work with it since. (Open to any feedback on this from you since you had a great work time with the liquid.) The results were great... it just looked like it snowed on every part of the vehicle. Knocked out some Type 1 water spots, some med. swirls, and probably filled some of that too. Didn't really do an IPA wipe because... the dude was selling it anyway.
    With Speed...
    I worked it on a black, Ford F150. Traditional D/A, 5.5" green, B&S pad, medium pressure, medium arm speed on speed 5. I made 7 section passes on each section... could have worked it a little bit longer. No dusting and I didn't prime the pad. I started with 6 small, pea sized drops, next section was 4 small, pea sized drops... 3 small pea sized drops every section after. Changed pads every panel. Cut was ok... not the same as 151 (for me, BUT the pad wasn't the same so I couldn't expect it to be anyway.) I have since tried Speed with an orange B&S pad and it doesn't seem to cut like 151 does.
    For what it's worth...
    -Dellinger
    Because you compared the two products on different vehicle surfaces, this was not a good test. Especially, since you mention that the D151 vehicle had thirsty paint, you used different pads, different arm speed & different downward pressure
    Combined with errors in technique, I am not surprised at your results with D151:
    if you are using so much product that the pad is saturated after half a panel...you are using way too much product, which leads to dusting
    Fast arm speed with a DA is poor technique and will to dusting
    Not priming the pad, bad. Although foam pads can "self-prime" after a couple of sections. Priming is recommended to maximize the amount of cut, consistency of cut and minimize marring from dry buffing
    If you were not priming the pad, how in the world was it "saturated" after half a panel?
  2. #32
    Regular Member Dellinger's Avatar
    May 2013
    Amboy, WA
    117
    Allen-
    I was not performing a test, as you allude to, with the AIO's. Simply stating my experiences.
    My stated technique above was obviously experimental regarding 151 since it was my first time using the product.
    Since the time of my prior post, I maybe have a 1/2 gallon left of 151... I have tried every possible different technique to keep the product from dusting and it simply doesn't matter.
    Agree on your fast arm speed comment... however, I was referring to a loose 1" per second... usually I move the machine drastically slower than that when using a dedicated polish. With an AIO I tend to speed it up to around 1" per second.
    I cannot explain the pad saturation either regarding 151? It still does it to this day... and makes absolutely no sense. Currently, if I am using 151 (which is rare because HD Speed is simply a better product for me) I will prime the pad and add 3- 4 dime/ nickle sized drops depending on the paint condition... and after a 2- 4 sections... the pad is very damp.
    Thanks for your thoughts though,
    -Gabe
  3. #33
    Jun 2013
    Montreal, Quebec
    3,996
    I am waiting for my order of CarPro Essence. When climate allows it I will try to do a 3 way test between Essence, Speed and D151. I will take into consideration what was suggested regarding product amount and polisher speed. I am also thinking I might have a bad bottle of Speed too. The product is really thick almost like a paste, this might be why it was dusting so much. Can't wait to try Essence though, I have a feeling this will rate really high in my recommendations to customers.
  4. #34
    Super Member 4u2nvinmtl's Avatar
    Jun 2015
    Montreal, QC
    443
    Quote Originally Posted by Calendyr View Post
    I'll come watch live! Really interested to see Essence in action...
  1. Quick Review -- Scholl Concepts SW20 Speed Wax
    By ScottB in forum New Car Care Products
    Last Post: 08-30-2016, 12:16 PM
  2. McKee's 37 360 vs HD Speed - A quick review and comparison
    By haris300 in forum Product Reviews
    Last Post: 06-13-2016, 01:31 AM
  3. 3D HD Speed or Meguiars D151
    By dakotaRT in forum Auto Detailing 101
    Last Post: 04-04-2016, 11:49 PM
  4. 303 Speed Detailer Quick Review
    By Jaretr1 in forum Product Reviews
    Last Post: 01-25-2016, 03:31 PM
  5. Quick Review -- Surf City Speed Demon Wax Detailer
    Last Post: 06-20-2008, 09:02 AM
