Just opened my box from cyber weekend and there is a white crystal/foam looking thing floating around in my OC syringe?!?! Anyone have any idea?? Plz help
Okay thanks... i was worried lol thought directions were.. "polish to perfection.... now grind these crystals into paint.... dont worry its okay" lol stuff is too expensive to waste
to me looks like some air was trapped between the seals and ended up hardening, seen it happen with glues in syringes before...they are trapped in the dead space between the seals so it should be fine. however if your really worried, slowly fill syringe with air with the "needle" end up and when the plunger gets to top of syringe you can put finger over the end of syringe and pull plunger out to clean the plunger's seal, but do this at your own risk as it did not come direct from optimum directly....so i would just use it how it is...
