question about Pinnacle Paintwork cleanser
So, the two times I've used this, I followed the machine directions of using the white pad. However I'm realizing that the white pad has a slight bit of cut. I wouldn't think I'd really want that if I've polished the vehicle previously with other abrasive based products. So if I was just wanting to strip the wax off and clean the paint in prep for a new fresh coat, can I use a gray pad instead? I started thinking about this after looking at the Dodo products for instance where their version of PCL says to use a gray pad. It makes sense following Mike's "least aggressive product" methodology.
Re: question about Pinnacle Paintwork cleanser
Depending on paint hardness or just technique, it is not unexpected that white can cause marring so a safer bet is to use a softer pad and still strip the paint.
McKee's 37 Product Support
Green Polishing or Tangerine Hydro-Tech are my two choices.
I think I used a red Griot's pad the last time I used it.
I say that you are OK with the white pad. I've used white with many chemical type cleaners with no marring to date. I would think that you want some pores since you might be pulling up some dirt.
There are many on here much more qualified to say so.............
Yes.
The combined forces at play,
- Oscillating Action
- Pinnacle Paintwork Cleansing Lotion
- Foam formula
- Pressure (even if light)
- Time (number of passes)
Should be more than enough to remove any wax or paint sealant off the surface and do it very gently.
Of course it goes without saying to make sure the car is spotlessly clean.
By dennis hiip in forum Auto Detailing 101
Last Post: 09-16-2017, 04:14 AM
By phosphene in forum Auto Detailing 101
Last Post: 04-02-2015, 04:25 PM
By swanicyouth in forum Auto Detailing 101
Last Post: 05-23-2013, 07:56 AM
By WickedLou9 in forum Auto Detailing 101
Last Post: 10-18-2012, 04:05 AM
Last Post: 11-10-2011, 10:31 AM
