Re: Machine applied paste wax
I use a paintbrush that is cut down. It applies to pad easier and still leaves the remaining product in the can neat. I really like applying by machine because you can get to wax so thin that any wax is a breeze to remove. Also applying liquids by machine basically makes a 16oz bottle last for years. I have a bottle of 845 that has been used appx 40-50 times and there is still a quarter of the bottle remaining.
Originally Posted by Emm
I thought I was in the minority, applying by PC 7424XP.
HA! You are now the Majority!!
e mail poorboys and ask them about putting it in fridge to harden it up so you can pop it out-i am sure others have contacted them with same question
Not a bad idea, it's pretty beat up from using a palstic putty knife to remove the wax. I would probaly have to remelt it
ED
______________________
CLUB FLEX 3401
Can't wait to use SN hydrid via DA!!
I hear you Mark, when do you get yours? I get mine Tuesday
ED
CLUB FLEX 3401
Ed, a week from tomorrow!
Mark, I'll let you know how it is, maybe Wednesday
ED
CLUB FLEX 3401
What speed is everyone using? I was using a putty knife to scrape DP Max Wax onto a LC blue flat pad, and on 3 it was turning even did it with just the weight of the machine.
Desert Detail
89 Toyota Cressida with a 2JZ....... Mmmmmmm boost.......
I use what BobbyG mentioned... soft paint brush, gently brush it on top of the wax to make it melt a bit then brush it on the pad. Spreads thinner and easier. Scrape knife makes a bit of a chunk and the wax's still solid. I often find chunks of wax still attached to my pad and did not distribute properly around it.
Another way is to use 4" spot pad, fuzion and souveran have the biggest pot, easy to swipe with it. Others might need to bend the spot pad a bit.
Also use speed 2 on my D/A, slower movement kept the wax spreads better, a good swipe can last through 3 panels. Faster speed would only dry the wax faster and spread it heavily on your first fly and only last on 2 panels at best...
By jankerson in forum Wolfgang Car Care
Last Post: 12-07-2020, 04:52 PM
Last Post: 08-25-2017, 09:35 AM
By joche26 in forum Auto Detailing 101
Last Post: 10-16-2012, 05:28 PM
By sshinn1 in forum Auto Detailing 101
Last Post: 02-17-2012, 10:48 PM
By Kaban in forum Auto Detailing 101
Last Post: 04-01-2011, 08:42 AM
