Re: Best finish polish
Should work fine...
My normal process would be to do a Test Spot first, make sure I can make one small section look GREAT and then go from there...
Thanks! will do a test spot on the wet-sanded repainted panel!
There with a microscope I can see like infinite scratches!
Hopefully after compounding and polishing there'll be
Originally Posted by cwpcasey
Yea! thats what I too noticed!
It also says that PO85U is formally know as PO85RD. So does mean its just a newer version of it?
Originally Posted by sohail99
Thanks a lot guys!
but mine is a soft clear coat! Is menz 85rd ok with that?
I am interested in the Menerna po85rd as well. I have a 2008 Denali and I'm not sure if my paint is considered hard or soft. Does the hardness or softness of the paint determine what type of finishing polish to use? I've recently been using the M205.
I had a doubt because I thought that since PO85rd is made for ceramic clear coats it might have lil' more cut(than required) on my Hyundai's soft clear coat.
Just a quick question, If I compound with UC, will I need to follow it up with M205 and/or PO85RD??
(I need as perfect a finish as possible!!! )
Yes you should be prepared to use M205 or PO85RD. In the prior posting you were worried that PO85RD had too much cut for soft paint. UC is pretty aggressive.
^Yea! Initially I thought 85rd was only for cerami-clear clear coats!
(every hr here I'm learning something new!)
Actually I'm dealing with a repainted panel which has been wetsanded by a detail shop!(they used a diamond cut compound without following it up with anything and used speed glaze to hide the compounding swirls!)
I want to restore these panels and the whole of the car to a show car finish!
On repainted panels I'm gonna do a test spot with M205 with a white LC pad and follow it with PO85rd.
I'll need UC if the above combo isnt enough for the job!
btw is UC followed by M205 followed by PO85rd, overkill??
Nope, I use these together allot.
M205 - 2500 grit
PO85RD - 3000 grit
Last Post: 04-12-2017, 08:56 PM
By Redfireshaker06 in forum Blackfire Wax Products
Last Post: 04-10-2016, 06:59 AM
By MA5177 in forum Auto Detailing 101
Last Post: 08-13-2015, 12:55 AM
Last Post: 04-12-2013, 02:18 PM
By primo spaghetti in forum Ask your detailing questions!
Last Post: 11-03-2012, 03:25 PM
