Originally Posted by tephra
I spoke to Jerry about #105/#111 and he said that #105 is "newer" and contains more cleaner as well.
From my experience #111 is a bit harder to apply (can't see it that well) and it's a smaller bottle/more expensive...
Although when asked about multiple coats, Jerry said that it was better todo multiple coats using #111, since #111 contains the least amount of cleaner...
#111 HAS NO CLEANERS, ITS A PURE SEALANT!
The words EXPENSIVE and DURAGLOSS are never to be used in the same sentence, ever!!
You may not be able to see DG #111 but rest assured, its going on the car, leaving it well protected and looking AWESOME!!!
DG #105 is a great all around product, adding #601 to ANY DG product makes it even better, almost wish that #601 was just mixed in from the factory and marketed as "new and improved" because it would be just that!
Yeah, I like and use DG products!!
2022 Elantra N Cyber Gray
Re: combining Duragloss 601 with 105 or 501
Originally Posted by BillyJack
Nothing special as far as application. Like any other cleaner wax you want to work it in well to take advantage of the cleaning and polishing ability. You can remove it panel by panel, or let the whole car haze off before removing.
Bill
So just put it on with a wax applicator pad, let it haze, and wipe it off with a microfiber? I have never used a sealer so this is all new to me..
Never used 105, but DG includes an applicator with 111. Perhaps they do with 105 as well.
My bottle of DG #105 didn't come with an applicator.
Well I'm doing what was recommended of 601 and 105 mixed together
Were you told the proper ratio?
Just beware to mix as close as you can as DG recommends using the mix with in 2 hours.
Dave
601 = Ketchup
105 = Mustard
Dave
Originally I was mixing up 2 oz of 105 with .5 oz of 601, but rarely use more than an oz of the mixture for body and wheels so started mixing 1 oz of 105 with 1 1/2 teaspoons (= .26 ozs) of 601--very little waste.
I mix on the pad, no bottles or measuring etc. 4 dots 501 or 105 and 1 dot 601.
By duffthebluff in forum Auto Detailing 101
Last Post: 01-21-2016, 04:54 PM
By Meticulous-Detail in forum Auto Detailing 101
Last Post: 11-14-2012, 10:43 AM
By chemguy626 in forum Off-Topic
Last Post: 09-10-2012, 11:46 AM
By jpnuzzo in forum Auto Detailing 101
Last Post: 11-13-2008, 02:40 PM
By pawpaw in forum Auto Detailing 101
Last Post: 06-09-2007, 10:09 AM
