Re: Turtle Wax Seal and Shine
Originally Posted by
Coatingsarecrack
I found SNS REALLY hard to remove. 4 sprays on Autofiber applicator and covered half the hood. Wiped with 365 gsm TRC. Buffed with 800gsm Everest.
Perhaps humidity related? I've found it very easy. Spray, wipe, buff. When done with the entire car, I go back over and remove any streaks with a damp MF Rag with nothing but distilled water on it. Perfect shine and super slick. Based on this ease of use and longevity related abuse I've seen it being put through and surviving online, it's now my go-to top layer for basic Polish and Protects and over top of my AIO's I use.
Klasse Act
Seal and Shine hard to remove....
Yes hard to remove..... just wiped down for 3rd time.
FUNX650
Just curious:
All these “issues”—yet adhering
to the product’s instructions?
Not issues.... issue
I applied to applicator wiped on wiped off..... unless it is different than the vast majority of sealants out their....
Maybe 4 sprays to much but I have not had problems removing ANY other product I applied.
Feels “greasy”
TTQ B4U
Maybe it’s cuz I’m not “buffing”. Seems like Reload/Clutch issues.
With Clutch they want you to let it set up for at least 15 min but leave on as long as you want. When I wait though it wipes right off
Gave it a good long buff and looks good.
[IMG]
Questions for users:
How much are you using on a panel?
How long has this product been out?
Coatingsarecrack
Did you not wipe it off after the application and let it sit for almost 2 hours?
What I have gotten from seeing application and have not used mine yet. Is that you would work in smaller sections. And use very sparingly and wipe it off directly after application. It's useally also cleans up the haze the first wash you do if you used a little to much or didn't been able to buff it off.
SWETM
I used 4 sprays on half a hood. I’m guessing to much? Even with heavy application I haven’t had that tough of problem with removal (Clutch was close) Tried 4 towels. Last one was creature edgeless. Maybe it’s because it has wax but most sealants I’ve used wipe on wipe off. This took some actually buffing but again I may have used too much product. It’s fine after a little elbow grease
I’m not trying to knock the product, just giving my experience. Shine Supply Clutch is finicky if you try to wipe away too soon and even let it “set up” for an hour you may need to use a damp towel or QD to wipe. I love the stuff.
Just giving my experience and time will tell if I like it.
Just use to cosmic and overcoat lately and stuff’s WOWO.
^^You tried buffing off immediately after spreading or did you wait extended time to buff off (was SWETM’s question)?
The only time I have had issues with ICE Spray Wax was when I did not wipe it off quickly. Just re-apply and wipe off in those cases.
I usually use it liberaly, spraying over entire pannel then using 2 towels to wipe off.
So far it's been a great product.
I was a bit disapointed in the durability of the Black Spray Wax from the test Jimbo did. I was expecting it to have similar durability to the ICE line. Unfortunatelly it really isn't as resillient.
