Page 20 of 24 FirstFirst ... 101112131415161718192021222324 LastLast
Results 191 to 200 of 237
  1. #191
    Sep 2017
    Sweden
    3,022
    Re: Turtle Wax Seal and Shine
    Okay so finally did a wash on the car with TW SNS. When applyied 6 weeks ago I did a decon wash. The weather was humid and right when I was done it started to rain. And the wipe off feeled grabby. So take what it's worth when I applyied it. The car has not been washed since then.
    I saw a couple of days ago when it had rained that a part of both the hood and the roof was showing failure of the SNS. After the ph neutral prewash foam and PW clean rinsing it off it showed total failure. And also after the wash with Carpro Reset car soap it still was dead. To some reference and cause of the finicky application I got. I only applyied SNS on the roof and the hood. The rest got the newer version of Gyeon Wet Coat. And this was like it was newly applyied after the prewash foam and the wash. Some transfered up on small parts of the hood and the roof. It's spreads like crazy LOL.
    Here is a picture after the rinse of Carpro Reset car soap. You can see some of the Gyeon Wet Coat beading on the edge to the hood. And how flat the SNS is. SNS was showing no sign of even sheeting.
    Maybe it's what to expect from the conditions I applyied SNS in. But on the other hand GWC shows a really strong behavior after the 6 weeks. And from what's been kind of expected longevity from SNS it should last longer than GWC. I will give SNS a try again. Sadly it started to rain again when I was going to apply it LOL. But will be doing it when possible. In better conditions and hope it shows me better results from it.
    / Tony
  2. #192
    Jun 2013
    Montreal, Quebec
    3,996
    Reset is a degreaser soap from what I understand. The idea of that product is to strip anything that might be stuck to a ceramic coating. So if you use it on a sealant, I would expect it to damage it.
  3. #193
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by Calendyr View Post
    With all this talk about how chemical resistant this product is, CarPro Reset should not have an impact on it.
  4. Likes SWETM liked this post
  5. #194
    Sep 2017
    Sweden
    3,022
    In the 1:500 dilution or sometimes weaker I have not experienced it to knock down any protection I have used it on. And it where flat already after the prewash foam and PW clean rinsing it off. 1:5 of the prewash foam in the foamcannon bottle and then 3 on the chemical mix setting on the foamcannon which is graded from 0-10. So no strong solution of the prewash foam either. And from all of the torture testing with TW SNS I think that it should stand up to these products. I used on the GWC on some places even a citrus based tar remover and Sonax Wheel Cleaner Max Effect which is their new stronger bleeding wheel cleaner than the Wheel Cleaner Plus. It didn't even show any degrading from that in the water behavior. And GWC was applyied in very light rain that took on later to more rain.
    Either it was the very humid conditions when I applyied it or it's sensetive to be applyied on a very clean and preped paint. But will give it a go again and apply it under better conditions. The grabby wipe off was not what I expected from it. Either the humidity or the just decon washed paint could be what didn't make SNS to bond properly. The spray on rinse off products I have experienced it bonds to not so well preped surfaces very good. So something was going on with my application of SNS. Will see how it goes next time I apply it. But just little over a month vs 4-6 months it's expected to last is strange.
  6. Likes Coatingsarecrack liked this post
  7. #195
    Kappy
    I have an unopened bottle sitting here, and wondered if there's any problem cleaning the towel used for buffing? If this holds up to so many different chemical torture tests, how is it removed from a towel using soap, or do you just use an inexpensive soft towel and toss it?
  8. #196
    Super Member Rsurfer's Avatar
    Jan 2007
    14,099
    Quote Originally Posted by Kappy View Post
    Since TWSnS is not a coating, removing the residue should not pose a problem.
  9. #197
    Super Member Oz_TCH's Avatar
    Jul 2012
    Northern Virginia
    370
    Bought it few weeks ago for $5.99 for 2 bottles.
    Used it 1st time today as quick drying aid. So far so good.
  10. Likes acuRAS82 liked this post
  11. #198
    May 2017
    Pittsburgh PA
    2,847
    Quote Originally Posted by Oz_TCH View Post
    That red looks amazing! Is there a base LSP on the car or SNS only?
  12. Thanks Oz_TCH thanked for this post
  13. #199
    Jul 2012
    Northern Virginia
    370
    I had clay, sealant and wax on it about couple months ago.
    Today, just wash and then Seal N Shine as drying aid, that's it.
  14. #200
    Jun 2013
    Montreal, Quebec
    3,996
    Wow! That is crazy! Here in Canada, 15,99$ per bottle at Walmart.
  1. Top Turtle Wax Ice Spray Wax with Turtle Wax Seal & Shine
    By Darren F in forum Auto Detailing 101
    Last Post: 07-31-2020, 01:26 PM
  2. Collinite 845 and Turtle Wax Seal and Shine
    By soapboxpreacher in forum Auto Detailing 101
    Last Post: 09-05-2019, 03:53 AM
  3. Turtle Wax ICE Seal N Shine - after or before?
    By CleanIT in forum Auto Detailing 101
    Last Post: 08-31-2019, 07:26 PM
  4. Turtle Wax ICE Seal N Shine - Engine Bay
    Last Post: 08-28-2019, 08:12 PM
  5. Replies: 30
    Last Post: 06-02-2019, 06:41 AM
