Cquartz
I applied cquartz for the first time today. I read that 1 30ml bottle will do 1 or possibly 2 cars. I watched a bunch of videos on how to do it. I put a streak down the pad with the microfiber that came with it and did that for every 2x2 section. Just repeated that for the whole car. I did have a hard time seeing flashing and leveling due to the color of my car (white diamond tricote). Can't even see swirls with my halogen lights and my 8-8' flourescent lights. I did the door jams, roof and everything that has paint on the car and still ended up with 3/4 of a bottle. Did I do it wrong? It's a Buick Verano so it's a smaller car but it still seems like a lot. I already did the reload an hour later.
Re: Cquartz
It is going to vary depending on the size of the vehicle. The verano is small sedan. It is recommended to apply a second coat to get a little more durability but to make sure you have even coverage.
You will still end up with a little coating left over. Enough to do two coats on the faces of the wheels or possibly one coat on the inner and faces of the wheels.
Re: Cquartz
If I wanted a second coat wouldn't I have to buff the car and start over again since I already applied the reload?
Re: Cquartz
I missed that you added reload. If you feel you got even coverage then leave it and enjoy.
Re: Cquartz
If you have another car you'd like to coat, plan on doing that in the coming few months so you use the rest of that coating. Or post it up for trade in the Samples thread, 3/4 of a 30ml bottle should be enough do do one more car and someone could use it. I'd skip the second coating on yours as you've already added Reload and that might make the coating not stick well and just go to waste. Or even worse, some weird cloudiness from getting stuck in between 2 layers of coating.
Re: Cquartz
I still have my wife's Jeep to do so I will use it for her car.
Let's hope the coating holds up.
Thank you!
By itsgn in forum Auto Detailing 101
Last Post: 01-18-2018, 12:23 PM
By MshawnBauer in forum Auto Detailing 101
Last Post: 08-28-2017, 10:24 PM
By Blackdevil77 in forum Auto Detailing 101
Last Post: 08-14-2016, 12:43 PM
By Jomax in forum Auto Detailing 101
Last Post: 10-09-2015, 01:17 PM
Last Post: 09-01-2015, 10:16 AM
