Looks good. Never heard of Prima Epic but it did a good job. Just wondering why did you do an IPA wipe down and what did you end up sealing the paint with? Either way nice job
Re: Can Prima Epic Be Used as an AIO
Thanks!
Prima Epic Synthetic Wax, liquid car wax, polymer wax, paint sealant
I did the IPA wipe to see the true condition of the paint since this was a test and I didn't want any sealant masking it. I haven't sealed the paint yet (I'm going to do a few more tests with this car) but when I'm done it'll be sealed with Epic.
I have been using Prima for years and you are absolutely correct, Prima Epic with an Orange Pad can work great as an AIO. It doesn't contain any abrasives but it does enhance the paint significantly and it helps lubricate the pad which is doing all the cutting.
I often find that after doing it this way, I go back to using Prima Swirl first, then using Epic as it's intended use as an LSP simply because the results are better and I often find myself wanting just a bit more cut. =)
Richard
Originally Posted by jakonrad
BlackWow, BlackWow Pro, Pre-Wow invented by Richard Lin and all available here at Autogeek.net
Richard
Thanks for the input!
I figured that what I was doing was using the cutting ability of the pad to clean up the paint. Would you say that using that aggressive of a pad with Epic would induce marring? I guess it doesn't matter as much since all I'm trying to achieve with this approach is a slightly better paint condition rather than a perfect finish for people who want their daily drivers to look a bit nicer. On the other hand, a dedicated AIO would probably finish out better.
On that note; what do you use for an AIO? I guess I've always just had a preconceived notion that using an AIO won't provide the level of protection that a dedicated sealant would and a dedicated sealant won't polish as well as an AIO.
By Matt@FourAcesMD in forum Auto Detailing 101
Last Post: 03-02-2014, 06:44 AM
By SR99 in forum Show N' Shine
Last Post: 05-27-2013, 08:50 AM
Last Post: 10-03-2012, 09:48 AM
By lkotsios in forum Auto Detailing 101
Last Post: 11-12-2011, 09:11 AM
By supercharged in forum Auto Detailing 101
Last Post: 02-23-2011, 08:41 AM
