Re: Chemical Guys Microfiber Detergent
I like the CGs microfiber detergent and buy it by the gallon. I bought some Blackfire restorer/detergent on BOGO and I think I like it better. The towels come out cleaner, however, I doubled up on the CGs product and the towels came out cleaner too. I think adding a little more of the CG detergent than recommended will do a better job for you.
Lately I have been dropping in a gel pac of All (the one that is "free" of of scents, softeners, bleach, etc.). This pac is in addition to the microfiber detergent. I find the towels are cleaner and softer. I am going to continue to experiment by adding regular wash detergent to the microfiber detergent.
After use and prior to wash, I also pre-soak my dirtiest towels in a tub of very hot water and OxyClean stain remover for about an hour or two, agitating and stirring the towels every now and then. I think this pre-soak is the best thing you can do for dirty towels. And in all cases, I give them a second rinse with white vinegar. The great assassin of microfiber is soap and I believe the extra rinse with vinegar helps to remove all soap in the towel. I need to edit this to add that I agree with you about the line air dry. I seldom dry my microfibers in the electric dryer.
Reason: addition
I have been using Detailers Pro Series Microfiber Cleaner Detailer's Microfiber Cleaner 128 oz. with good results.
I put 2oz in 3 gallons of water in a bucket. As I use towels, I throw them in the bucket to soak and then dump the bucket into the washing machine and add another 2oz and wash on HOT.
I tested the water going into the wash at 147F. I bet the temp drops substantially when the water hits the 72F metal washing machine tub.
The tag on some microfibers I recently purchased indicates "Do not heat above 195F"
I check the towels before I put them in the dryer and if they are not very clean, I hit the dirty spots with Shout and rewash w/ 2oz of DPSMC.
This seems to work every time.
I was happy with the results. I haven't tried the vinegar on the rinse cycle but will have to. Does it make the towels feel different or just aid in all the wax etc. residual removal?
I have not tried anything else with the Chem Guys cleaner but maybe will try a touch of liquid detergent of another brand just to see.
Detailers Pro Series Microfiber Cleaner is on Sale right now
I use CG's microfiber detergent and a scoop OXY. If they are real dirty I just let them soak in that for an hr. This works great!
I've use CGs, DP, and Blackfire. It just seems towels come out the nicest with BF. CGs I liked the least, but its not too bad.
CG, 19.99 for a gallon doesn't hurt and its dine good by me! But Blackfire is the best, too bad the price on the gallon jumped. Cost is a deciding factor for me at least.
Back to the full-time grind.
It's okay to wash with hot water in the washing machine? I know it's bad to use hot air
I use hot water and dry low heat, never have seen any issues. People tend to over think towel care. use a good detergent, and you'll be fine!
By specv10 in forum Product Reviews
Last Post: 08-23-2013, 10:40 PM
By david11g35 in forum Product Reviews
Last Post: 03-04-2013, 07:58 PM
By ihaveacamaro in forum Auto Detailing 101
Last Post: 09-09-2012, 12:15 PM
By krazieY in forum Auto Detailing 101
Last Post: 05-21-2012, 09:54 AM
By mets2010 in forum New Car Care Products
Last Post: 03-13-2012, 06:26 PM
