Results 1 to 6 of 6
Thread: Gtechnic P1
    Newbie Member royale's Avatar
    Nov 2006
    Gtechnic P1
    Has any one ever used this? I tried doing a search but no results showed up. According to some you- tube videos, it does a pretty decent job. Can someone chime in to tell me know the in's and out's of this product? Not much on this product on the forum
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Re: Gtechnic P1
    Quote Originally Posted by royale View Post
    P1 is a water based nano polish. It's pad dependent, meaning the more aggressive the pad, the more the cut. I would compare P1 to Menzerna SI1500. If you need more work time, just a spritz of water and it will reactivate the polish. Being a water based polish, just water to clean up your pads. P1 has become my go to polish.
    Regular Member gtechrob's Avatar
    Sep 2010
    103
    Re: Gtechnic P1
    hiya
    thanks for the interest in p1.
    our pSystem polish system (p1, p2 and x3 hotswap pads) is pretty different to most polish systems out there.
    as Rsurfer says - P1 is water based. it is non diminishing too.
    the key to this polish is that we have managed to source a very consistent and very tiny abrasive particle. this means we do not need to have anything like the amount of lubricating oils a regular polish does. in turn this means that you will get more abrasives working the surface albeit on a much smaller scale. think of it as more of a rounding action than a cutting action and for some paints it actually "reflows" the surface. this illustration is slightly overegging the effect but it gives you the idea:
    also I have put some other pieces of info and youtube shots of it working on the p1 shop page on our site:
    Polishing // G|Techniq
    but.... (there is always a but when it comes to polishes!!) if you are a commercial "detailer" can you replace all your polishes with p1. the answer has to be no. for some paints, pSystem just isn't going to be fast enough to remove RIDS and you will have to resort to a good old fashioned cutting compound particularly for very hard lacquers such as mercedes, audi, bmw - and we found the paint on a couple of current model mustang paint exceptionally hard.
    however for pulling out defects on medium to soft paint, pSystem is going to work a lot faster.
    hth
    Re: Gtechnic P1
    I've used and comparison tested the P1 Polish and it's a very good polish, I'd classify it as a Medium Cut Polish so for most people it will tackle most of anything you want to remove.
    Like a lot of products you can control it's cut by your choice of pad, fiber or foam, aggressive or non-aggressive. Same goes for tool choice, for faster and more cut use it with a wool pad on a rotary buffer, for less cut use it with a foam polishing pad on a DA Polisher.
    Don't buff to a dry buff, you should always see a film on the surface behind your path of travel.
    Wet Buffing Technique
    Wet film behind your path-of-travel
    Here's some info on categories of aggressiveness, this is just a portion of the below article,
    Word Definitions - Compounds, Polishes, Glazes, Paint Cleaners and Waxes
    Quote Originally Posted by Mike Phillips
    Judge a product by the function it performs, not the name on the label
    Because there's no universal or industry accepted standards for definitions for words and terms used in the car care appearance world, my practice and recommendation to others is to judge a product not by the name on the label but by what function the product serves.
    For example if a product is referred to as a polish but acts as a paint sealant, then the product is in fact a paint sealant and not an abrasive polish in the historical use of the word.
    If a product is referred to as a glaze but acts to seal the paint with some type of water insoluble paint protection ingredients, then the product is a wax or a paint sealant or some hybrid variation of a wax or paint sealant and not a glaze in the historical use of the word.
    Here's a list of commonly used words in our industry and my attempt at creating some type of standardized definition for each word.
    Aggressive Cut Compound
    Medium Cut Polish
    Fine Cut Polish
    Ultra Fine Cut Polish
    Non-Abrasive Glaze or Pure Polish
    Pre-Wax Cleaner
    Paint Cleaner
    Carnauba Wax
    Synthetic Paint Sealant
    Hybrid Sealant/Wax
    Paint Coating
    Cleaner/Wax or AIO
    Below are some descriptions for each category.
    A very aggressive liquid or paste that uses some type of abrasive technology to cut or abrade paint quickly. In the body shop world, compounds are used to remove sanding marks. In the detailing world, compounds are used to remove deep below surface defects like swirls, scratches and water spot etchings. Depending upon the abrasive technology and the application method and material, some automotive compounds can remove down to #1000 grit sanding marks. Of course topcoat hardness is an important factor that affects compound effectiveness at removing below surface defects.
    Historically, the more aggressive the compound, the more follow-up polishing will be required to restore a defect-free finish. Due to major advancements in abrasive technology, the trend is for very aggressive compounds that finish out like medium and even fine polishes.
    In most cases an aggressive compound should be followed with either a medium polish or a fine polish to refine the surface to a higher degree of finish quality than the results produced by only the compound. Most compounds are dedicated products in that their function is primarily to abrade the paint. For this reason, after the compounding step further polishing and then sealing steps are required. Most compounds are water-soluble so that they can be washed, (dissolved with water and soap), off body panels and out of cracks and crevices.
    Medium Cut Polish
    A liquid or paste that uses some type of abrasive technology to cut or abrade the paint but is less aggressive than a true cutting compound. Depending upon the abrasive technology and the application method and material, some medium polishes can remove down to #2000 grit sanding marks and finish out to LSP ready. Topcoat hardness is an important factor that affects a medium polish's effectiveness at removing below surface defects.
    Most medium polishes are dedicated products in that their function is primarily to abrade the paint. For this reason, after the polishing step further steps are required, which may include another final polishing step depending upon the results after using the medium polish and the expectations by the user for the end results. At a minimum, the paint should be sealed with a wax, paint sealant or coating.
    Fine Cut Polish
    A liquid or paste that uses some type of abrasive technology to cut or abrade the paint but is less aggressive than a true medium polish. Depending upon the abrasive technology and the application method and material, some fine polishes can remove down to #2500 grit sanding marks while still finishing out LSP ready. Topcoat hardness is an important factor that affects a fine polish's effectiveness at removing below surface defects.
    Most fine polishes are dedicated products in that their function is primarily to abrade the paint. For this reason, after the fine polishing step further steps may be required. This could include another final polishing step depending upon the results after using the fine polish and the expectations by the user for the end results. At a minimum, the paint should be sealed with a wax, paint sealant or coating.
    A liquid or paste that uses some type of abrasive technology to cut or abrade the paint but is less aggressive than a true fine polish. Depending upon the abrasive technology and the application method and material, some ultra fine polishes can remove down to #2500 grit sanding marks while still finishing out LSP ready. Topcoat hardness is an important factor that affects an ultra fine polish's effectiveness at removing below surface defects.
    Most ultra fine polishes are dedicated products in that their function is primarily to abrade the paint. For this reason, after the ultra fine polishing step at a minimum, the paint should be sealed with a wax, paint sealant or coating.
    Historically, the term glaze is used to describe a bodyshop safe, hand-applied liquid used to fill-in and mask fine swirls while creating a deep, wet shine on fresh paint. It's a category of products used on fresh paint in body shop environments, which will not seal the paint surface by depositing a long lasting sacrificial barrier coating using some type of protection ingredients.
    A bodyshop safe glaze is used in place of a wax, sealant or coating because it won't interfere with the normal out-gassing process of fresh paint for the first 30 days of curing. The function of a bodyshop glaze is to hide rotary buffer swirls while giving the paint a uniform, just waxed appearance to ensure customer satisfaction. After 30 days cure time its normal to the seal the paint using a wax, paint sealant or coating.
    In the near future we'll do a Thursday Night Live Broadcast using the P1 polish plus some other Gtechniq goodies...
    Feb 2012
    Palatine Illinois, USA
    24,546
    Would this be a good product to follow Meg's UC with?
    2022 Elantra N Cyber Gray
    Nov 2006
    Quote Originally Posted by gtechrob View Post
    hiya
    hth
    So based on the pad I can manage the different cuts. Can this polish be used then as jewelers polish, say if I used a black or red hexlogic foam pad? Also, what would be the ideal working speed using a porter cable 7424 orbital?
    This is great, thanks for the feedback
  1. Clean and coated my convertible top (gtechnic)
    By Coatingsarecrack in forum Auto Detailing Tools and Accessories
    Last Post: 01-25-2020, 09:42 PM
  2. Gyeon vs. GTechnic which do you prefer.
    By Lamented in forum Auto Detailing 101
    Last Post: 07-17-2018, 08:14 AM
  3. Dlux vs Gtechnic C4
    By dchristo in forum Auto Detailing 101
    Last Post: 03-23-2015, 03:52 PM
  4. Recommended towel for removing Gtechnic C1
    By ralphwiens in forum Auto Detailing 101
    Last Post: 04-03-2013, 04:19 PM
  5. Gtechnic Crystal Lacquer
    By LAMF in forum New Car Care Products
    Last Post: 09-03-2012, 06:44 AM
