Re: Review: BlackFire Wet Diamond Sealant
Originally Posted by Waxmax
BFWD is a great sealant. I've used it many times. On dark colors (incl. black) it gives a great deep look with excellent reflection and incredible slickness...ala a wet diamond.
I have never had the dusting or re-hazing (sweating) problems mentioned in the OP. I am sure many others will chime in now on its merits. Great to see Blackfire and Todd Helme added to PBMG.
I'm sure you're going to say it doesn't need it, but have you topped it with a wax? like Fuzion?
Dave
Black is not a color, it's a part time job!
Corey did a great review. Like you I never had a sweating problem, a little dusting, but no biggie.
I have been using BFWD for about a year and really like it. Great shine and very slick. Easy on and off and it doesn't stain trim. Even though I own a PC and a Flex 3401 I prefer to put on sealants by hand. I use a sponge applicator and it goes on very thin as it should and NO dusting. I did use it with a microfiber applicator once and I couldn't get it on thin enough due to the texture of the applicator and had some light dusting.
BFWD!! Something else I have to get..
S2K- regarding topping BFWD with carnauba, I've done it a few times...with Midnight Sun, also Fuzion and Souveran.
The difference in look is subtle...maybe a little richer look, but BFWD really does not need it, IMO. Sometimes I feel like using a carnauba, sometimes not. It's all good.
Thanks, but it could be fun to try anyways.
Dave
Really nice review Corey!
The dusting, from my understanding, is caused by the actual drying agents in the product, which where added to the line (along with polycharger) around 2008-9ish.
Ultimately BFWD does not need to haze prior to being wiped off. You can apply it and remove it immediately with little to no effect on durability. I will usually apply it with a gold pad on a PC around speed 3. I can cover about 1/3 of a normal sized car with just a few drops, then I come back and buff that section off immediately. This seems to drastically cut down on both the streaking and dusting issues that may occur in humid climates on some paints.
BFWD was designed to be fool-proof to a larger degree than most other sealants. Want to buff it off wet? No problem. What to wait until it hazes? No problem. Want to do half you car, grab a beer, watch Mike Phillips on Speed, then buff it off, no problem.
Thanks for the review.
I really like with with Blackfire Midnight Sun Carnauba, either batch #24 or #25.
The wax was developed to specifically 'bond' (term used loosely) to the extremely slick surfaces that modern sealants like BFWD are noted for. It has a small polymer blend that it is similar to the polymer used in BFWD.
458 Italia with BFWD/MS
Do you do the small areas you can't get with the PC by hand before or after you do the large areas by machine?
Dave
Very interesting and great info Todd. I was under the assumption that it was like most others - wait until it hazes before removing. I used this a few weeks ago with a great outcome and the client was very happy with the slickness of the paint. Maybe one day I'll get around to applying LSP's by machine vs. hand. Do you know if the gold pads will come over with the BF line? Thanks for sharing.
By Sonic Pilot in forum Blackfire Wax Products
Last Post: 09-28-2017, 10:55 PM
By DylansDetailing in forum Hot topics & Frequently Asked Questions
Last Post: 03-21-2015, 04:34 PM
By Bigbull2984 in forum Product Reviews
Last Post: 10-25-2013, 12:31 PM
By nbroph34 in forum Auto Detailing 101
Last Post: 05-16-2012, 10:01 PM
By 05xrunner in forum Product Reviews
Last Post: 08-03-2011, 08:02 AM
