SELF BANNED
Re: LC 3.5" backing plate
Sorry to hear about this Ron, I will ask the most obvious question, were you using too much pressure. Also how old is the backing plate? I know a couple years ago there was a bad batch running around but since have fixed that. I am glad it was a headlight vs. having to get the paint repaired.
It's about a year old, Dana. Not a lot of pressure, about 10 lbs. If you look at the photo, I put an X on the plate in order to see if the pad is spinning. I've used it mostly to polish lenses and maybe a couple of times to do some touch up. I would estimate that I have used it for no more than 1 hr. in 3 times.
SELF BANNED
With your knowledge I know it isn't user error, it has to be a defect. Sorry to hear about the headlight, but like I said above if it is going to happen that is a better place than the paint.
If I had used it to spin dry a pad I can see it happening, but I never spin a pad unless it's on a surface like paint or my lights. Let's hope it's a defective bp and won't happen to someone else. I'm getting a rotary bp which is built much stronger.
Super Moderator
Is this the one you were using? Either way give us a call and we will take care of you.
By MartyK in forum Ask your detailing questions!
Last Post: 05-31-2020, 02:42 AM
Last Post: 03-03-2016, 11:43 AM
By dennis hiip in forum Auto Detailing 101
Last Post: 09-16-2014, 05:01 PM
By ryanmcg1 in forum Product Reviews
Last Post: 09-29-2011, 11:29 PM
By Mindflux in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-09-2010, 11:48 AM
