Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. #31
    Aug 2022
    Dana Point CA
    1,322
    Re: Tire Dressing Applicators
    I use these for my brushes:
    Amazon.com
    Also use them for my flex parts. and odds and ends.
  2. Thanks Prange, Icarus thanked for this post
  3. #32
    Dec 2018
    7,177
    Quote Originally Posted by chefwong View Post
    I like these for the most part - but it's not a -saver- for me. I find I use 2X versus a foam or brush mainly because the MF does soak up a bit of it.
    Sometimes 3-4 spritzes per tire = 6-8 using the *saver* app
    I see the opposite. Foam applicators or the brushes suck it up. The saver’s barrier keeps it on top.
    I find I use about half (1 to 1.5 pumps) per tire. I was using 2 plus with the foam I tried. The brush soaked up to much with TWGATC so I haven’t tried directly applying with the brush now. Just leveling.
  4. #33
    May 2007
    668
    Product Consumption Aside, I do like the styrofoam blocked Microfiber.
    The MF material and the Firm Block allows me to scrub the dressing in certain sidewalls...that has all sorts of nooks and crannies. It's also firm enough for me to level it as the final pass without needing a towel to do it. Unlike a softer material (brush or foam), I still need to use one of those to get in the area where the bead meets the wheel (my use case is mainly low profile rubber).
  5. Likes DFB liked this post
  6. #34
    May 2020
    89
    Quote Originally Posted by Gridlink View Post
    I did a little searching and found them on Amazon item#B08C73BRLK for a 6 pack but you can get a 3 pack for $3 less. I'll be buying a 6 pack since it's a better value, and they also come in a black, blue, and red version to help differentiate which applicator is for which tire dressing. The smaller size will be perfect for lower profile tires.
    I've bought from Carzilla before but shipping to the US is a bit pricey if I'm only placing a small order.
    Mine arrived today with a bit of an issue. They come in a plastic bag inside of another thicker plastic bag and the whole thing is then vacuum sealed. Someone at the factory ripped open the inside bag, took 2 of the 6 applicators out, and then vacuumed sealed the whole thing.
    Replacements are already on their way.
  7. #35
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Why, those Sons a B!tches!!
  8. #36
    SELF BANNED
    Jun 2019
    1,076
    wrong thread!
  9. #37
    May 2020
    89
    Well I'm happy to be wrong. The applicators were so compressed due to the vacuum sealing that it only looked like two were missing. They've been out on a table expanding for the last couple of hours and to my surprise all 6 are there.
  10. Thanks noorth thanked for this post
  1. Tire Dressing Applicators?
    By CleanIT in forum Auto Detailing 101
    Last Post: 07-24-2021, 10:02 PM
  2. Tire dressing applicators- storage and cleaning
    By davidc11291 in forum Auto Detailing 101
    Last Post: 05-26-2012, 12:40 AM
  3. About Tire Dressing and Applicators
    By Jsuro in forum Tricks, Tips and Techniques
    Last Post: 03-06-2011, 05:11 PM
  4. Tire Dressing Applicators From Harbor Freight
    By tenorplayer23 in forum Auto Detailing 101
    Last Post: 11-06-2009, 01:30 AM
  5. Flex Foam Tire Dressing Applicators
    Last Post: 04-14-2007, 08:08 AM
Members who have read this thread: 5
