Re: Tire Dressing Applicators
I use these for my brushes:
Amazon.com
Also use them for my flex parts. and odds and ends.
Post Thanks / Like - 2 Thanks, 0 Likes, 0 Dislikes
Originally Posted by
chefwong
I like these for the most part - but it's not a -saver- for me. I find I use 2X versus a foam or brush mainly because the MF does soak up a bit of it.
Sometimes 3-4 spritzes per tire = 6-8 using the *saver* app
I see the opposite. Foam applicators or the brushes suck it up. The saver’s barrier keeps it on top.
I find I use about half (1 to 1.5 pumps) per tire. I was using 2 plus with the foam I tried. The brush soaked up to much with TWGATC so I haven’t tried directly applying with the brush now. Just leveling.
Product Consumption Aside, I do like the styrofoam blocked Microfiber.
The MF material and the Firm Block allows me to scrub the dressing in certain sidewalls...that has all sorts of nooks and crannies. It's also firm enough for me to level it as the final pass without needing a towel to do it. Unlike a softer material (brush or foam), I still need to use one of those to get in the area where the bead meets the wheel (my use case is mainly low profile rubber).
DFB liked this post
Gridlink
I did a little searching and found them on Amazon item#B08C73BRLK for a 6 pack but you can get a 3 pack for $3 less. I'll be buying a 6 pack since it's a better value, and they also come in a black, blue, and red version to help differentiate which applicator is for which tire dressing. The smaller size will be perfect for lower profile tires.
I've bought from Carzilla before but shipping to the US is a bit pricey if I'm only placing a small order.
Mine arrived today with a bit of an issue. They come in a plastic bag inside of another thicker plastic bag and the whole thing is then vacuum sealed. Someone at the factory ripped open the inside bag, took 2 of the 6 applicators out, and then vacuumed sealed the whole thing.
Replacements are already on their way.
Gridlink
Why, those Sons a B!tches!!
Well I'm happy to be wrong. The applicators were so compressed due to the vacuum sealing that it only looked like two were missing. They've been out on a table expanding for the last couple of hours and to my surprise all 6 are there.
