Feedback on a great suggestion - McKee's N-914
I recently coated the bike with Polish Angel Cosmic V2 Glass Coat, and then topped with PA's High Gloss.
It's been ridden and has been filthy and cleaned a few times already.
ECH2O is my go to regular wash. When I'm done, I dilute it a bit more and it makes a great detailer for the final buff. Good stuff.
Once a month or so, I plan on reapplying PA's High Gloss.
Before applying, a good guy here suggested I use McKee's N-914. I did and it works great
I put one ounce in 2 gallons of water, soaked plush 16 x 16 MF cloths and then used those to carefully clean every surface, nook and cranny. It feels pretty slick, does a great job of lifting dirt and grime, even on mag wheels with some built up brake and road grime. It was nearly streak free and looked great when I was done. Afterward, I carefully went through the bike and dried it off. I'm not sure if any of the original High Gloss topper remained, but the cleaned surface looked great.
Once cleaned, I reapplied two coats of High Gloss.
I love N-914 for how I'm using it, it was a great suggestion.
Here's a pic after it was cleaned and sealed with two coats of topper.
