Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Super Member Jacob Harrod AUTOCLEAN's Avatar
    Mar 2020
    El Reno, Oklahoma
    754
    Sonax The BEAST Wheel Cleaner Review
    This is my review of the Sonax "The BEAST" Wheel Cleaner.
    First up let me start off by saying that I felt that these wheels were a true test of this wheel cleaner. I mean these things were absolutely DESTROYED. I knew my normal go to wheel cleaner was underpowered for the task, so I ordered me a bottle of the Sonax "The BEAST" Wheel Cleaner.
    SONAX The Beast? Wheel Cleaner
    It's really nice that you get a liter bottle and initially I was worried that I wouldn't have enough. I'll talk about this again towards the end of this review. At first I thought they cheaped out and just used the same sprayer as they did on their glass cleaner but the truth is is that both the sprayer from their glass cleaner and this sprayer work pretty good.
    As you can see from this photo the spray pattern from the sprayer on The BEAST Wheel Cleaner sprays a more narrow beam of product compared to the fine atomization that their glass cleaner sprayer sprays. I think I said that right.
    In my opinion this is the correct spray setting for the cleaner to be applied and this allows you to also spray the product in the barrels of the wheel as well.
    Here are some pictures that show how heavily contaminated the wheels were...
    My process for cleaning the wheels is as follows:
    I started off by reading the directions on the bottle.
    DIRECTIONS:
    Shake the bottle, turn the pump sprayer nozzle to the spray position.
    From a short distance, generously and evenly spray cooled and dry wheel rim.
    Allow to work for 2-4 minutes.
    The color quickly turns red and unleashes its full cleaning power.
    Remove deep dirt contamination with a brush.
    Rinse the cleaner completely off with a strong jet of water or high pressure cleaner.
    Do not allow to dry.
    After reading the directions I sprayed the product on to the wheel and in the wheel barrel and let it dwell for 4 minutes.
    You'd better have a strong stomach or a respirator because this stuff STINKS indicative of a product that contains iron removal agents.
    One thing I will say is that I wish it said straight up weather or not it has iron decontamination or not on the bottle just for clarity. I know after smelling the tell tale scent and witnessing the deep purple bleeding effect I believe I can say with certainty this product does indeed contain iron remover.
    Here are some pics of it in action
    Looks like delicious purple jelly but I wouldn't recommend putting it on your toast!
    After allowing the product to dwell I rinsed the wheel thoroughly sprayed some more of the cleaner on and then agitated with a brush to scrub the wheels clean.
    I truly can't believe how easy this stuff made it on me as the heavy contamination just came right off with the exception of the front driver's wheel which had a heavy contamination of oil and grease in the barrel of the wheel, but the face of the wheel still came clean.
    I probably could have used the whole bottle and it would not have gotten the barrel of that wheel clean. I believe you'd need some heavy solvent based degreaser to get that oil and grease off.
    I did a finger swipe so you can see here in this pic.
    Sonax "The Beast" Wheel Cleaner is a heavy hitter on even the most contaminated wheels and going back to what I said earlier about being worried about not having enough, Well let me just say that even though these wheels were what I thought were past the point of no return this stuff restored the wheels and I only used just over a half of a bottle!
    Quite literally the most impressive non acid wheel cleaner I've used to date!
    Here's some before and after action!
    These wheels are absolutely shimmering again thanks to THE BEAST WHEEL CLEANER!!!
    I give this product 5 stars!!!
  2. Thanks Diner thanked for this post
  3. #2
    Super Member 01GreyStangGT's Avatar
    Aug 2009
    Springboro, OH
    857
    Re: Sonax The BEAST Wheel Cleaner Review
    Looks like a great product! Thanks for the detailed review. We need more of those. Sonax The BEAST Wheel Cleaner Review
    2014 Ford Mustang GT Track Pack-Black
    2015 Chevrolet Silverado Crew Cab 4x4- Summit White
  4. Thanks Jacob Harrod AUTOCLEAN thanked for this post
    Likes Jacob Harrod AUTOCLEAN liked this post
  5. #3
    Mar 2020
    El Reno, Oklahoma
    754
    Quote Originally Posted by 01GreyStangGT View Post
    My pleasure! Glad you enjoyed it!
  6. #4
    Jan 2015
    Simi Valley, CA
    1,783
    Nice work... On the wheels and the review.
  7. Thanks Jacob Harrod AUTOCLEAN thanked for this post
  8. #5
    Mar 2020
    El Reno, Oklahoma
    754
    Quote Originally Posted by 2black1s View Post
    Thank you!
  9. #6
    Super Member spazzz's Avatar
    Jan 2014
    Madison
    1,013
    Thanks Jacob, I have been waiting for a review.
    Do you think it would cut if diluted?
    Maybe fill the rest of the bottle with distilled water/give it a go and post the results here? just an idea.
    Lovely product I am sure. I have used the 2 previous versions and the results are quite pleasing.
    Now let's talk price/+shipping........okay, maybe not.
  10. Thanks Jacob Harrod AUTOCLEAN thanked for this post
  11. #7
    Super Member Rsurfer's Avatar
    Jan 2007
    14,100
    Quote Originally Posted by spazzz View Post
    Great product, but pricey.
  12. Thanks Jacob Harrod AUTOCLEAN thanked for this post
  13. #8
    Mar 2020
    El Reno, Oklahoma
    754
    I'm no chemist so I can't speak on how well it would work if diluted.
    That would be a nice feature if they had some dilution ratios on the bottle for applications that require less cleaning power.
    I'd like to see it sold in a gallon jug RTU as well.
    You can get it for a cheaper price if you hit a 20 - 25% off sale and say you order 100 bucks worth of stuff, you'll get free shipping.
  14. #9
    Jan 2007
    14,100
    Quote Originally Posted by Jacob Harrod AUTOCLEAN View Post
    Yeah, a 32oz bottle of wheel cleaner doesn't go very far.
  15. Thanks Jacob Harrod AUTOCLEAN thanked for this post
  16. #10
    Sep 2020
    Eastern PA
    1,815
    It's actually cheaper per oz for the 1L bottle then the 5L jug of wheel cleaner plus.
  17. Thanks Jacob Harrod AUTOCLEAN thanked for this post
  1. SONAX "The beast" wheel cleaner.
    By PA DETAILER in forum New Car Care Products
    Last Post: 01-21-2021, 06:35 PM
  2. Sonax Wheel Cleaner Plus - Review
    By DaytonaJae in forum Product Reviews
    Last Post: 05-22-2014, 04:47 AM
  3. Replies: 10
    Last Post: 01-17-2013, 04:56 PM
  4. Review: SONAX Full Effect Wheel Cleaner
    By mchess1 in forum Product Reviews
    Last Post: 09-05-2010, 03:31 PM
