Griot's BOSS Surface Wash...
I've tried a ton of snow foams, and there's only a couple that actually WORK!! This is one of them. I used a 2800 PSI, 2.3 GPM gas pressure washer, MTM PF22 Foam Cannon, Pink Metering Tip I bought from Griots(fit inside the PF22 tube perfect). AS you can see in the pics, it actually encapsulated the dirt, not just on the paint for show. Pressure rinsed and 90% of the dirt was gone. So, you will have far less grit on the paint prior to a contact wash. Love this stuff and it smells GOOD, like pina colada.
I should have got a before picture, but decided to do this halfway through...lol
Re: Griot's BOSS Surface Wash...
Follow up with the Surface Prep to strip off all the old, foam with Poly Gloss and you have a clean and protected car that the paint wasn't even touched!! Good stuff with this system!
Mike
Bought into this system when it was released- So far I’ve been really happy with it. Like you say - it’s not just a gimmick, that foam’s really accomplishing something.
Does Autogeek have it yet? I’ve got a review of it over on the sister site I could bring over...
Looking forward to trying the Surface Prep! Bummer so far it’s only available in gallons; I think I’d be stocked for years!! Liking the Poly Gloss, it’s actually serving as the only LSP on my daily at the moment. (Not what it’s designed for, but I was curious, and it’s easy!)
