Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Review - Sonax CC36 Ceramic Coating
    Disclaimer: Meghan sent me this product to review. Thank you Meghan for sending it out to me.
    Product: Sonax CC36 Ceramic Coating
    Price: $79.99
    Product description:
    SONAX CC36 Ceramic Coating is not a wax or paint sealant. In fact, it's much different. This two-stage coating blankets your vehicle's paintwork in a flexible shell of extremely glossy protection that lasts years, not months. Compared to a conventional wax or paint sealant, SONAX CC36 Ceramic Coating provides superior gloss and better resistance to environmental impacts such as bird droppings, water spots, car wash scratches, and more. SONAX CC36 Ceramic Coating is for the person that wants the best protection for their vehicle!
    SONAX CC36 Ceramic Coating is the most advanced surface care enhancement product to ever come from Germany.
    Here's what SONAX CC36 provides: incredible gloss, sheeting that is out of this world, superior longevity to any wax or sealant, and ease of application. SONAX CC36 Ceramic Coating will redefine how you detail your vehicle.
    SONAX CC36 does more than sit on your paint. A special bond is created between product and surface, protecting against hostile environmental hazards and providing a lasting, glass-like finish.
    SONAX CC36 Ceramic Coating is an all inclusive kit that requires no special training or equipment needed to apply. Even if you are not a professional detailer, you can certainly achieve professional results with SONAX CC36 Ceramic Coating.
    With protection that lasts up to one year, SONAX CC36 Ceramic Coating gives you peace of mind. Rather than having wax your car every 2-3 months, simply take care of the existing coating and you're surface is glossy and protected!
    Don't leave your vehicle unprotected simply because you think you're not ready for a coating. SONAX CC36 provides durable protection, and insanely gloss finish, and can be applied without special equipment.
    Extend the life of both your paint AND its shine with SONAX CC36 Ceramic Coating.
    Directions for use:
    • Using your preferred method, thoroughly clean the paint and polish with a machine to a high-gloss finish with no swirls or holograms. The surface needs to be absolutely clean before SONAX CC36 Ceramic Coating is applied.
    • Using the enclosed applicator labeled 1, apply SONAX BaseCoat (1) in a thin layer. For sensitive paint surfaces, the enclosed Microfiber Cloth can be used wrapped around the applicator.
    • Treat a small surface area using a criss-cross sequence. Allow to dry for approximately 30 seconds to 1 minute at the most, then wipe the treated surface with a clean microfiber towel to a streak free shine.
    • Repeat this process until the entire vehicle is treated and allow to cure for at least 1 hour - make sure the surfaces are not touched and do not get wet during this curing process.
    • After the prescribed curing time, apply the SONAX GlossCoat (2) to achieve a superior smoothness and deep shine. Spray the product directly onto white side of the applicator labeled 2 and spread over the surface.
    • You can treat areas of a half bonnet in size, which then need to be wiped over with a microfiber towels to remove excess product (drying is not necessary).
    SONAX Pro Tips:
    • Do not apply SONAX CC36 Ceramic Coating onto hot surfaces.
    • To ensure a perfectly smooth and even application, working in a well-lit garage is recommended.
    • Within an hour of applying SONAX BaseCoat, missed areas or streaks can be dissolved and removed by applying the product again.
    • The sealed vehicle should not be washed within the first three days after being treated, and when it is washed, do not use a high alkaline cleaner. Do not polish the vehicle after treatment.
    I held off on the review for this one to get more time to share my experience over a longer period of time. That way I could give a better overall view of the coatings performance.
    Again after having my car repainted a year ago, it was time to correct and coat it. I corrected it back in June of 2017.
    One thing I should mention is that with the new paint job, there is a lot of paint on the car to work with. The reason for the paint was that the paint under the clear coat had begun to fade. It was on the front fenders, some of the front doors and the lower rocker panels. The front and rear bumpers had clear coat failure. The original paint was 17 years old.
    But the roof developed rust. It snuck up on me. The windshield was replaced long ago so it must not have been a good job. This was not a pretty sight.
    I posted some photos here of some of the defects that were on the car. I also posted the Sonax polishes I used in this same thread. For those that don’t want to click on the link the polishes were Sonax Cut & Finish used with various cutting pads and Sonax EX 04-06 Finishing Polish on various polishing/finishing pads.
    Review - SONAX Paint Polishing Foam Pads
    Here is one more that I found in broad daylight on the trunk. Rotary holograms and swirls courtesy of the body shop.
    At the end of the day these are the pads I was testing the polishes on. All these pads worked well with the Sonax polishes.
    The paint was washed, decontaminated (mechanically and chemically) using the Aggressive Wash Method. It was polished and prepped prior to applying the coating.
    The Aggressive Approach to Washing a Car
    I am going to leverage off of the how to write up from Mike Phillips as well as post my thoughts on the use of it. I will also be posting some long term updates on having this on my car.
    See the following How To Article by Mike
    How to use the SONAX CC36 Ceramic Paint Coating
    The packaging is nice and directions are pretty straight forward.
    Sonax CC36 Ceramic Coating is a two part aerosol system. It comes with Step 1 which is the Base Coat and Step 2 which is the Gloss Coat. The kit also includes a pair of gloves, marked applicators and a suede microfiber. The aerosol cans and applicators are clearly marked. The applicator pads are also sized differently.
    Each can comes with 2 oz’s of product. That is enough to do one small car and up to a mid size car. Two kits would need to be purchased for anything larger than that.
    The kit does not come with any prep solution. The European kit comes with the prep spray. The reason we don’t get the Sonax prep solution is that it is not VOC compliant. I used some CarPro Eraser to remove any polishing oils. I was not too concerned if everything did not come off considering the product synergy.
    The difference between Mike’s How To is that I used the included marked applicator. Applicator 1 (used with the base coat) wrapped with the suede applicator.
    From listening to the Sonax reps at the demoing of the coating, they mentioned that the suede applicator is meant for softer paints. They also mentioned that for darker colored paints to help with the leveling of the coating to avoid high spots which are easily seen on dark paints.
    There is only one suede applicator. Which is to be used with applicator 1 for applying the base coat. Applicator 2 for the gloss coat is to be used as is.
    I used the applicator wrapped with the suede. The reason being I didn’t like the foam applicators dragging on the paint. They squeaked way too much for my liking and dried out much quicker compared to the suede applicator. The suede stays primed longer.
    These are the conditions that I was applying in.
    The higher humidity caused the base coat to flash quick. For those in higher temps the coating will flash faster and that is normal. The Base Coat is the only part that needs to flash. The Gloss Coat does not need to flash. Essentially wipe on wipe off.
    It is recommended to allow 1 hour between the Base Coat and Gloss Coat. Only one coat of each is needed. There is not much Gloss Coat so that one goes by fast. One could get away with a second coat of Base Coat but that is not really needed.
    This is an example of the Base Coat flashing and ready to be leveled out.
    Photo of me wrapping up for the night.
    Finished photos a few days later.
    A few weeks later in the full sun.
    A couple more random shots
  2. Thanks Bruno Soares, Desertnate, Diner thanked for this post
    Likes SWETM, Angus, SNP209, Desertnate, Loach and 2 others liked this post
  3. #2
    Jun 2013
    LA, CA
    8,719
    Re: Review - Sonax CC36 Ceramic Coating
    My original intent was going to be using Sonax Brilliant Shine Detailer after every wash. But I changed my mind. I have since decided to use it every now and then but still leave one area untopped (driver side of the hood) to see how the coating does over 1 year. The other times I am using McKee’s N914 (waterless wash mixture) as my detail spray after every wash.
    Final thoughts:
    I have to give a thumbs up to this coating at the 3 month mark. It is holding up very well.
    Bird droppings are easily removed from the painted surface. I can literally blast a bird dropping off the paint with a few pulls of a trigger from a bottle full of McKee’s N914 (waterless wash).
    There has been no water spotting. It did rain a couple times during the summer monsoon weather. But no water spotting.
    It has kept the paint looking clean and has maintained the gloss from the polishing job I did on it. The gloss on the silver paint looks great even if the paint is dirty.
    It makes washing effortless and saves me time.
    It is not a slick coating. It is a bit grabby. Not many coatings are slick to begin with but in comparison to those that I have used this one is by far the most grabby. Does not really bother me but it may bother others.
    Application is straight forward. Spray onto the applicator, apply to the paint and level out.
    The con I have with this is the price for a 1 year coating. This is offset by any sale.
    Another con is the amount of coating included. I have a little base coat left but I did not have enough gloss coat to finish off my car. I had to use another coating for the front bumper for this reason. The Sonax reps did say that one kit is good for a small car and up to a mid size sedan. Anything larger and 2 kits would be needed.
    I also did not like the foam applicators. They tend to drag and squeak on the paint as the coating is spread out. They did not allow the product to spread out in a larger area. This could have been due to the humidity. I preferred the wrapped applicator with the suede.
    As I wrap this write up up I should mention that Sonax intended this coating for the professional and thus the 1 year claim. They feel that the professional can schedule their customer to come back in a 1 year for a re-polish and re-coat to get more money in the detailer’s pocket. Rather than offering a multi year coating where the customer may not return.
    They also mentioned that if someone wants to get 3 years out of this coating, then they recommend applying Sonax Polymer Net Shield every 4-6months. Apparently PNS and CC36 share similar chemistry. Some may be turned off by this. I will not be doing this as I will be letting the coating run it’s course for 1 year.
    I also asked about chemically decontaminating the coating. The rep I spoke to said to not use an iron remover on it as it could degrade the coating. I can not comment on that. Perhaps I will test that after 1 year. The rep did say their Multi Star APC would be ok.
    After all this I would recommend giving this a try for someone looking to get into a coating. I can’t comment on longevity yet but I will report on that at the 1 year mark to evaluate the coating.
    But at 3 months it gets a thumbs up.
    Thanks for reading and stay tuned for an update at the 6 month mark.
    I took this video a two weeks after the coating cured. The coating has a very aggressive water behavior.
    I have had the coating on the paint for 3 months. I took a video of that as well. At 3 months it is holding up very well. Water behavior is still aggressive.
  4. Thanks Desertnate, Diner thanked for this post
    Likes SWETM, Angus, Marc08EX, Loach, Rmd and 2 others liked this post
  5. #3
    Super Member atgonzales's Avatar
    Oct 2013
    744
    Nicely done
    http://Www.gonzodetailing.com
    Anything in life worth doing is worth over doing, moderation is for cowards.
  6. Thanks The Guz thanked for this post
    Likes The Guz liked this post
  7. #4
    Super Member Angus's Avatar
    Jun 2012
    1,583
    Great review, as always, Guz!
    CC36 isn’t talked about a whole lot on the forums - Meghan certainly knew the right guy to do a comprehensive review on it
  8. Thanks The Guz thanked for this post
  9. #5
    Feb 2014
    Rochester MA
    2,627
    Nice review bud! Car looks awesome. Wouldn't mind getting mine repainted.
    I have some of the same paint issues on my 2000 Grand Prix GT. Unfortunately I think it's head gasket time. Going to the shop today. Have already replaced all the usual suspects of coolant issues. Upper and lower intake gaskets, metal coolant elbows, water pump, radiator and a whole new upper manifold.
    IGL Authorized Coating/Kenzo Installer
    Final Inspection Auto Detailing- https://www.facebook.com/FinalInspection
  10. Thanks The Guz thanked for this post
  11. #6
    Super Member EWtheDETAILER's Avatar
    Sep 2012
    Princeton, Indiana
    341
    Nice write up Guz! I have the kit, but haven't applied it yet... sounds like I may need to purchase a second one before tackling my Toyota Tundra...I love the sonax quality, but for $160.00 for a large vehicle, for a one year coating, I'm thinking this is becoming less appealing....
    Keep Calm... and Detail On!
    Eric
  12. Thanks The Guz thanked for this post
  13. #7
    Super Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,253
    Nice review. Will be curious to see how it holds up over time.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  14. Thanks The Guz thanked for this post
  15. #8
    Aug 2013
    St Louis metro (Illinois)
    5,849
    Great write up. I appreciate the objectivity. It provides anyone looking to buy plenty to think about.
  16. Thanks The Guz thanked for this post
  17. #9
    Super Member Marc08EX's Avatar
    May 2008
    4,108
    Nice review Mike. Looks like it's holding up well.
  18. Thanks The Guz thanked for this post
  19. #10
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by atgonzales View Post
    Nicely done
    Quote Originally Posted by Angus View Post
    Quote Originally Posted by Marc08EX View Post
    Thanks guys.
    Quote Originally Posted by Justin at Final Inspection View Post
    Thanks. I always joke that the repaint costs more than the car is worth lol. But I am planning to keep it a little while longer.
    The head gasket going bad is usually rare for these engines but it does happen.
    Quote Originally Posted by EWtheDETAILER View Post
    Thanks. I'd be curious if one kit is enough for your tundra. It may be enough considering the the bed is open compared to an SUV which is all enclosed. I think you will have enough base coat but the gloss coat tends to go a bit faster. I think it is because it is more of a foam looking consistency.
    Quote Originally Posted by RippyD View Post
    Thanks. Same here.
    Thanks. I agree. It is costly for someone with a larger vehicle.
  1. Replies: 37
    Last Post: 11-26-2018, 09:53 AM
  2. Sonax CC36 ceramic coating questions
    By jdeday in forum Auto Detailing 101
    Last Post: 11-14-2018, 05:56 PM
  3. How to use the SONAX CC36 Ceramic Paint Coating
    Last Post: 09-20-2017, 03:47 PM
  4. SONAX CC36 Ceramic Coating
    Last Post: 04-24-2017, 03:24 AM
  5. SONAX CC36 Ceramic Coating Now Available
    By The Guz in forum Auto Detailing 101
    Last Post: 03-13-2017, 09:30 AM
