Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Super Member Angus's Avatar
    Jun 2012
    1,583
    Boyd Coddington One Step Wheel Cleaner - Review
    For this review I’m going to share my thoughts on using Boyd Coddington One Step Wheel Cleaner for the very first time:
    *Bias Review Disclaimer* AG sent me this item in exchange for a reivew at no-charge. Ok now that bit of housekeeping is out of the way… Onto my review!
    From AG’s copy:
    Boyd Coddington One Step Wheel Cleaner is an all-purpose, acid-free, and pH balanced rim and wheel cleaner that is 100% safe on all wheels (including billet aluminum!). Using the unique color changing formula, Boyd Coddington lets you know when it’s working by turning from clear to red when contact with brake dust occurs! Whether you have expensive custom-made wheels, or you just like to keep your wheels brake-dust free, Boyd Coddington One step Wheel Cleaner is just what you need!
    Over the years I’ve used a lot of different wheel cleaners. You name it - I’ve probably tried it. All in an effort to keep my dust happy BMW rims clean. And as much a Sio2 or SiC coating helps to create a dust barrier allowing for easy maintenance cleaning with nothing more than a soapy brush… every so often I still need to break out the “big guns” and use a ferrous metal removing product.
    Enter Boyd Coddington One Step Wheel Cleaner.
    Instructions
    1) Spray on Wheel Cleaner holding bottle 6-8 inches from the wheel surface. Spray the entire rim, caliper and tire.
    2) As the product begins to work and release the dirt and brake dust, it will change from clear to red. - Check
    (The above GIF = 3 ˝ minutes timelapse.)
    3) Allow the product to work for up to 5 minutes. If product dries, simply re-apply.
    4) Use high-power water to rinse the cleaner from the wheels. Re-apply if necessary.
    6) Dry wheel with a clean towel or premium microfiber.
    (I used my MasterBlaster after the below was taken to dry the rim)
    Overall Boyd Coddington One Step Wheel Cleaner knocked out 90% of the brake dust/ grim after the first application. The remaining 10% was due to me missing a few spots and required a follow-up application:
    Observations
    When I first smelled Boyd Coddington One Step Wheel Cleaner “cherry” scent I initially thought it was just going to be a rebranded version of Iron-X. But it’s not! What impressed me with Boyd Coddington One Step Wheel Cleaner is how well it clings and doesn’t run off onto the ground the moment you spray it. This allows for better cleaning because the product stays on the intended surface and has a better chance of breaking down and lifting away the contaminants w/o the need for vigorous scrubbing.
    To test this, hypothesis I grabbed a bottle of another ferrous iron remover, 3D BDX, and sprayed ˝ of another rim with it and the other ˝ with Boyds:
    Can you see how much thicker Boyds is on the left? (sorry for the photo not being centered)
    This gave me an idea - what if i put a foaming sprayer on the bottle?
    Would using it boost the already impressive cling?? Short answer: YES!
    50/50 using both sprayers:
    And time lapse of both sides - take a look at the bottom of the tire:
    Do you see how much is running off the left vs right?
    On to another rim using the foaming sprayer only:
    Take a look after ~4 minutes at how little product has run off the tire and onto the ground:
    Practically nothing. It stays right where I want it on the rim surface cleaning:
    Conclusion
    Boyd Coddington One Step Wheel Cleaner is a great product and one you shouldn’t overlook. I was honestly surprised how well it works and how little I needed to agitate with a brush afterwards. I used ~25% of the bottle to clean all 4 rims - I probally would have used less had I not been playing around with various sprayers and trying to make cool GIF’s for you guys
    If you’re in the market for a wheel cleaner make sure to check this one out!
    Super Member Marc08EX's Avatar
    May 2008
    4,108
    Re: Boyd Coddington One Step Wheel Cleaner - Review
    Spectacular review Angus! Love the GIFs!!!
    It's great to hear that this wheel cleaner clings to the surface well. Great idea on using a foamer too!
  3. Likes Angus liked this post
  4. #3
    Aug 2013
    Tustin, CA
    4,389
    Excellent review!
    CJ
    Save the Manual!
  5. Likes Angus liked this post
  6. #4
    Super Member ScottH's Avatar
    Nov 2015
    Northern NJ
    895
    Great review. I tested the same product several months ago and the only con to me was the smell long after the detail was over. The stuff soaks into the pavement and you smell it for days to come especially when you get the pavement wet again. It hangs around ....
    ScottH
  7. Likes Angus liked this post
  8. #5
    Nov 2015
    Los Angeles, California
    13,835
    Outstanding review. Boyd Coddington One Step Wheel Cleaner - Review
  9. #6
    Apr 2013
    1,266
    Great review man ! Looks very good
  10. #7
    Nov 2009
    Pasadena, CA
    12,615
    Outstanding review! Looks like an excellent product!
    '03 Corvette Z06
  11. #8
    Super Moderator Meghan's Avatar
    Mar 2006
    Florida
    15,036
    Awesome review, great photos, video and explanation!
  12. Thanks Angus thanked for this post
  13. #9
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    Wow! Excellent review on the Boyd Coddington One Step Wheel Cleaner. Keep up the great work!
    https://www.autogeek.net/boyd-coddin...l-cleaner.html
  14. Thanks Angus thanked for this post
  15. #10
    Super Member Pats300zx's Avatar
    Mar 2006
    Middletown, Del
    5,297
    Great review Angus !!!
    Only Z Best Detailing-Automotive Concours Detailing Services
    http://ozbdetailing.com
    https://www.facebook.com/ozbautodetailing
  16. Likes Angus liked this post
  1. Boyd Coddington Detail Garage: Product line review
    By Eldorado2k in forum Product Reviews
    Last Post: 01-03-2018, 07:40 AM
  2. Replies: 12
    Last Post: 10-28-2017, 08:53 AM
  3. Boyd Coddington Detail Garage Products - Test / Review
    By Bobby B. in forum Product Reviews
    Last Post: 10-17-2017, 12:21 PM
  4. Review: Boyd Coddington Wheel Cleaner
    By ScottH in forum Product Reviews
    Last Post: 04-24-2017, 10:37 PM
  5. Boyd Coddington
    By joe.p in forum Off-Topic
    Last Post: 06-19-2006, 04:20 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
