Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Aug 2013
    St. Louis, MO
    580
    Makita PO5000C Review
    I recently received the Makita PO5000C as part of a very generous giveaway here on the forum. I played around with it some this week and wanted to offer my thoughts.
    If you are not aware, the Makita offers the ability to switch back and forth between free spinning and forced rotation mode, offering some very nice versatility. I will spare you the initial walk around of the machine, as Mike Phillips has already done a tremendous job documenting this and I feel I wouldn’t add much value to it; you can Mike’s review here. https://www.autogeekonline.net/forum...-phillips.html
    I do want talk about it compared to the Flex 3401, Rupes 15MKII, and Griot’s G21 machines. I currently own and use the Rupes and Griots, but got rid of my Flex about 2 years ago, so I have a good amount of experience with all those machines. I do not do production level work, but do work part-time on weekends usually doing correction jobs, so these machines are “babied” compared to how some use them, and this point of view is coming from someone not using them day in and day out.
    First up, the comparison pictures:
    Makita is a bit longer than the other machines. I like this. It feels like I have more control over it. The handle is longer then the Griots and more easily grippable than my Rupes because of the rubber. Everything else is pretty similar. The backing plate shape is weird – perhaps Mike P. or someone can shed some light on why it was designed like this.
    Ergonomics: The Makita @ 6.2 lbs is heavier than the Rupes or the G21 but that’s not a bad thing. It feels very solidly constructed and it reminds me of the first Jurassic Park movie when the lawyer says to the kid: “Are those heavy? Then they’re expensive – put them back!”
    You can tell this was carefully engineered and constructed. I specifically appreciate that the handle is long enough to accommodate my hands and that the handle has a textured, rubber grip on it. It makes it very comfortable to hold, maybe even moreso than my G21 which is currently the most comfortable to grip. The knock on the Griots is that the handle is a little shorter and my hand wraps around it. I wish that the speed dial clicked. It’s a little preference of mine.
    In terms of smoothness when polishing, it’s extremely smooth, and I found that it was easier to work with than my Flex was. Maybe my hands have just toughened up a bit in the past two years. Either way, it’s still the same story with the machine wanting to “walk” on you. You just have to be aware of your technique. It’s certainly different from a normal free spinning DA. It also didn’t seem to get very hot. The Flex used to really warm up. Not sure if they have a different cooling method in the construction, but I did appreciate that. It is not as smooth to use as my Rupes, which recently has been punishing me the least out of my machines. My G21 has a washer mod and a smaller backing plate, which I do think adds to the vibration.
    It does stall a fair bit in free spin mode unless you are working on the highest speed setting, and even then you should be keeping the pad flat and paying very close attention. Forced rotation mode is likely going to be the bread and butter of this machine. I found that thinner pads worked best for me, and unfortunately I don’t have any hybrid pads to test which I believe many people like on the 3401.
    Noise: I used an app on my phone to read the decibel levels of all three machines I compared. They all were right around 77-78, which the app read as “loud music”.
    I found the noise pitch to be most comparable to the Rupes, whereas the Griots seems a little higher. This is probably all subjective, but just something to note. It’s no better or worse than any other machine I’ve used.
    Correction capabilities: I’ll honestly keep this brief – this machine is perfectly capable of achieving high quality results. Here are a few pictures of a slightly swirled up trunk that I was able to correct in just a few passes in forced rotation mode. I used Optimum Hyper Polish and an orange lake country pad.
    As you can see, it can get the job done. No point in delving too deep into this, since we know it’s going to get results.
    Overall, I think what sets this machine apart aside from the obvious ability to switch between free spin/forced rotation mode is the brand and build quality. Everything on the machine is just solid and feels nice.
    Something interesting I found: to most forum junkies or people that are plugged into the detailing industry and community, we know that Griots, Rupes, Flex, etc. put out high quality machines. However, a lot of people don’t have a clue that those companies even exist. When I was doing some testing my dad saw the Makita and said “hey, that looks like a nice machine.” He recognizes the Makita brand and that alone makes it appealing for a number of people who may not know how good other machines might be – the fact that they made a quality machine worthy to stand alongside the other more popular polishers is great.
    Thank you for reading and for AGO for the great opportunity/giveaway. Again, this is all very subjective but I hope I have given you some information if you were on the fence about purchasing this machine.
  2. Thanks RamAirV1 thanked for this post
    Likes RamAirV1, Martin53 liked this post
  3. #2
    Super Member atgonzales's Avatar
    Oct 2013
    744
    Re: Makita PO5000C Review
    Nicely done
    http://Www.gonzodetailing.com
    Anything in life worth doing is worth over doing, moderation is for cowards.
  4. #3
    Super Member Marc08EX's Avatar
    May 2008
    4,108
    Very nice review Heisenberg!
    If you could only buy one polisher, which one would you get?
  5. #4
    Aug 2013
    St. Louis, MO
    580
    Quote Originally Posted by Marc08EX View Post
    Hard to say, but probably the G21 or the Rupes. Forced rotation tires me out, and I like the ease of long throw machines.
    The practical side of me loves the G21's warranty but there is something so well-crafted about the Rupes that I can't quite put my finger on it. If the Rupes used a little more rubber on the grips/head of the machine it would really seal the deal for me in terms of ergonomics. I also used to think the G21 was as smooth as the Rupes but paired with their specific manufacturer pads I think the Rupes takes it in terms of comfort.
  6. #5
    Super Member cleanmycorolla's Avatar
    Apr 2012
    Pasadena, CA
    3,805
    excellent review.....
    Back to the full-time grind.
  7. #6
    Super Member DETAILROOKIE's Avatar
    Jan 2016
    1,160
    Thank you for your great review. After all of the negative reviews I read, I was planning on steering clear of the Makita and getting the flex, but your review has made my decision a little harder now. Thank you again!
    Sent from my SAMSUNG-SM-G935A using Autogeekonline mobile app
  8. #7
    Super Member VISITOR's Avatar
    May 2007
    9,773
    Quote Originally Posted by DETAILROOKIE View Post
    when there is a side by side (apples to apples/oranges to oranges) comparison with the flex then that would be more of a decisive factor in purchasing the makita (at least for me). even if you were to purchase the flex now, you can't go wrong it's a beast of a machine...
    thanks to the OP for the review..
  9. #8
    Jan 2015
    Simi Valley, CA
    1,783
    What direction is the rotation and is it the same in both modes?
    The CCW rotation of the Flex is the only reason I've never seriously considered it. I know others have said the CCW rotation is no big deal to them but I've been using CW rotating polishers since the 1970's and I'm not about to spend $$$ on a CCW rotating machine now.
  10. #9
    Super Member Route246's Avatar
    Mar 2017
    NorCal - San Mateo County
    1,037
    Where are the Makita and G21 made? Country of origin is important for some people. Rupes and Flex are European.
    Also, Makita has a good service center network for repairs and claims. Not sure about getting a Rupes or Makita serviced. I understand Griot handles all claims internally.
  11. #10
    Nov 2009
    Pasadena, CA
    12,615
    Nice review. I had a chance to play with the Makita for a bit and like you said, it definitely works better with thin pads. If I had to guess, I'd say the Makita in forced mode corrects faster than the 3401. Any forced rotation polisher is going to have the tendency to "steer" or "walk". I found the Makita to feel smoother/less vibration than the 3401(not that it was bad).
    Free spin mode is worthless.
    Quote Originally Posted by 2black1s View Post
    Counterclockwise is both modes.
    '03 Corvette Z06
  1. Anyone else order a Makita PO5000C?
    Last Post: 12-01-2018, 05:49 AM
  2. Review: Makita PO5000C Orbital Polisher - Gear-driven and Free Spinning - Mike Phillips
    Last Post: 11-26-2018, 04:10 PM
  3. Replies: 37
    Last Post: 11-26-2018, 09:53 AM
  4. Makita po5000c users
    By tucko in forum Auto Detailing 101
    Last Post: 06-21-2018, 09:18 PM
  5. Makita PO5000C/6000C
    By VISITOR in forum Auto Detailing Tools and Accessories
    Last Post: 02-26-2017, 01:07 PM
