Results 1 to 6 of 6
Thread: Opti-coat
    May 2013
    352
    Opti-coat
    A number of years ago I used Optimum Opti-coat on a very soft black paint. It was a life saver because the Optimum added a layer which was harder than the factory paint and I didn't have to chase after the small surface scratches. It became an almost full time job keeping the paint near perfect, and I was getting very close to the primer layer before being recommended to use this product. I noticed that the product is no longer available to a previous consumer such as me.
    Is there anything out there that is as good as the original Opti-coat.
    Thanks
    Sep 2016
    128
    Re: Opti-coat
    Quote Originally Posted by bcgreen View Post
    Thanks
    Optimum Gloss Coat is the consumer grade coating of their line. I've been very happy with it, but have never tried the pro versions to compare.
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Re: Opti-coat
    Gtechniq Crystal Serum Light is one of the more scratch resistant consumer grade coating in my experience.
    http://www.autogeek.net/gtechniq-cry...rum-light.html
    this coating by Gyeon says this is the hardest consumer grade coating?? I don't have any personal experience with it, but have heard good things about the product line.
    GYEON Q2 Mohs Ceramic Paint Coating - 30 ml
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
    Super Member BadgerRivFan's Avatar
    Aug 2015
    Mt. Horeb, WI
    884
    Re: Opti-coat
    If you are still dealing with soft paint, or paint with a minimal amount of clear coat remaining and you are planning to use a coating...
    Check out Essence Xtreme Gloss Enhancer as a primer for your coating. Essence contains some fillers and SI02 which can help "strengthen" your paint in some respects before applying your ceramic coating.
    Best used with a CarPro Gloss Pad using slow to medium speed and no pressure on soft paint. Great gloss and really enhances any coating. Check it out, might work for you!
    http://www.autogeek.net/carpro-essence-xtreme.html
    ​Al Schmidt
    "Adventure, is a car called Riviera..."
    Super Member tpr1634's Avatar
    Apr 2012
    South Jersey, just not far enough south
    1,160
    Re: Opti-coat
    As far as opti gloss I'm going to find out, I have never used a coating first time for everything.
    Super Member Znig22's Avatar
    Jun 2013
    Greenville SC
    386
    Re: Opti-coat
    Optimum Gloss Coat replaced the older version of Opti Coat 2.0 that I believe you are referring to. Although Optimum Gloss Coat is a Superb Consumer based coating and will do everything it claims it will, It does not compare to a Permanent Coating Like Opti Coat Pro or Opti Coat Pro Plus, 2 very different chemical make ups! The Permanent Coatings will require you to navigate to OptiCoat.com and locate a licensed installer in your area.
    PCB Reflections LLC
    Specializing in Corrections and Protection
    Servicing Greenville SC & Surrounding Areas
  1. Old, Original Opti-Coat vs. Newer Opti-Gloss vs. something else ??
    By Jed Clampett in forum Auto Detailing 101
    Last Post: 02-22-2017, 08:33 AM
  2. Replies: 12
    Last Post: 01-16-2014, 02:16 PM
  3. Replies: 11
    Last Post: 04-13-2012, 03:23 PM
  4. Opti-Coat/Opti-Guard and Poli-Seal Problem
    By gmck in forum Auto Detailing 101
    Last Post: 11-29-2011, 07:33 AM
  5. David F. Opti-Coat Test & What to do with Opti-Coat?
    By Old Tiger in forum New Car Care Products
    Last Post: 01-16-2010, 03:52 PM
