My unbiased (nightmare) review of PBL V2 Diamond paint coating and Wolfgang Uber Ceramic
Hello all,
Before I begin, I must say, I know 100's of you have had amazing results, and I am really happy for you all. But not all of us have amazing results unfortunately.
Onto my review....
Disclaimer: I know that I had made a mistake of not using the WG Paint prep spray properly, which might skew the review against myself, but taking that into account, I will still continue with my review if I may.
PBL V2 - Subject was a 8 year old Honda Pilot, completely a mess (separate show and shine to come)
The SUV was completely polished out using Ultimate compound, on a White Hybrid pad and my Flex.
Sample image:
Weather and surroundings: Covered garage, not fully closed but I have a roof and garage door and one wall. The other two “walls” are open to the path towards my rear garden straight up and to my front garden to the right. Plenty of wind due to the pathway having two walls on either side, towards my rear garden. 100 degrees ambient and 70-80% humidity.
Coating application:
I wiped the whole car down with Paint Prep, but like I said just once, and went to apply the coating. This could have hampered a lot of it but…..
Initial impressions:
1. Okay nice…it’s a spray…it should be easier to apply. WRONG!
The atomization might be a good thing, but, even a slight breeze and most of the product goes everywhere except where you want it to i.e. Overspray. Some of you like this aspect of the coating, I personally hated it.
Okay…I can live with that, I do have a full bottle after all.
2. Not at all user friendly. Flashes within 5 seconds…no joke
I remember Mike@Dedicatedperfection’s video on youtube that I watched close to 10 times and read his review as well. I read Nick’s comment saying that you should use a little more product. So…to be safe…I used 5-6 sprays per section instead of the 3-4 recommended.
The product was so annoying to work with that even when sprayed heavy, it would leave splatter marks. As in where the spray landed, I would work it in and wipe off and can see the splatter pattern, suggesting it was curing as soon as it hit the paint. What a PITA….
I did 75% of the SUV, except the roof with PBL v2. The roof got Menzerna Powerlock.
When I was 60% through, I had enough and called Andre@Autogeek and spoke to him regarding my problems. He said both PBL coatings are extremely tough to work with in conditions that are not temp controlled or indoors, going against all the marketing hype of the easiest coating to use. He suggested I work the product extremely heavy, say 8 pumps where they would recommend 3 and wipe of while still very wet…So I went ahead with that. The product was still flashing Insanely fast!
I felt I could finally work it for more than 5 seconds. WRONG…
Like I said, I thought I could….It was still flashing quick so I spread to a smaller section even when so heavy and wiped off….first wipe, flip over second wipe, grab another towel, final buff. All using a short nap. I used close to 30 towels on the car.
Same area as before:
All in all, I found this product quite difficult to use.
I would like to say, I might…and that’s a big “might”, have had different results if prepped properly, but that would not stop that ridiculously quick flash time.
Would I buy this product again?
No. Maybe if I had a temp controlled garage.
Would I recommend this product to others?
Yes, as long as you have a temp controlled environment, OR at least a garage that is completely sealed , four walls and a garage door. This way run a portable AC unit at least!
Overall impressions: Hard to use, but the finish was SUPER SLICK! My gf doesn’t care as her car looks brand new and she’s not worried about the high spots one bit.
LOL!
Re: My unbiased (nightmare) review of PBL V2 and Uber Ceramic
Onto the Wolfgang Uber Ceramic review:
Test Subject: Honda Accord V6 Sport 2016. Golden Brown Metallic – my car
Car was polished with M205 and a finishing pad on my flex as that’s all it needed to remove some light marring. A white pad was used on the rear bumper, trunk and front bumper. This is because I was in a fender bender and the 2 bumpers were replaced/repainted and they wiped my entire trunk down with dry towels *cringe
I like the syringe a lot! More than the PBL spray. I used a pair of pliers to remove the white tip and replaced it with the blue tip, tighten with pliers and voila. Nice!
I did the same thing as before with the WG paint prep and suffered with streaks, but stopped right after one panel instead of stopping when I was 60% done with the car lol.
Streaks visible right in the center of the picture:
And this point I called Andre again and we spoke for a good 25 mins (again) and towards the end I brought up my WG paint prep technique and we zeroed down on this being the issue:
I followed his advice to use 2 towels and 2 spray downs for each panel. Follow second spray down with a dry plush towel for buff off of residue. Worked like a charm and I could feel the final towel drag on the paint: suggesting bare paint.
Awesome.
I then started to work on the roof and was happy with the results, I worked it a little heavier than recommended. I used a heavy X for each section and wiped of wet for the whole roof. I spread the product around, but this spread out was quite difficult. Most of the product would get deposited on the part that I touched the panel first with the applicator. This made the spreading out a little difficult.
Picture this: you have a small square that you are working on. You touch the panel to the left top of the square first and the start to spread the product. From the left to the right. The left side has thick wet product and towards the end of small section to the right, there’s barely any product and its already flashing, while the left most areas is still wet with product. To counter this I would take some product from the left side so to speak. Not spread, and then start spreading from right to left. Now the center of the section is the one with the least product and is flashing.
I would quickly spread as much as I could and then proceeded to wipe of. I would take little bites instead of rubbing from one end to one end. This ensured, to my eyes at least, that all product had wiped off. I then would flip over to a dry side and buff again and then grab a new towel and do a final buff.
I then took a break when I finished the roof. Placed my syringe, blue tip facing up, resting on my LC applicator pad and went for dinner. This was a 30 min break.
I came and was greeted with this:
The syringe was leaking. I had not noticed this before as I kept placing it on the stool next to me which had textured pastic and was silver/grey. It probably leaked there too but I could not see it. I now could not do anything as this had cured. I looked at my syringe and the tip was tight but the product was oozing from around the blue tip.
Unknown to me, the syringe was clearly leaking while I was checking. It had then dripped on the door that was done, so I noticed it hours later. At this point I was at 8ml remaining….this is only after doing my roof and one door………
Drops can be seen against the white pillar as a backround:
Today evening, almost 20 hours later:
A total of 10 drops on this door and the big blob on my sunroof. Not so happy with that.
Anyways, I thought I was applying it properly. When I started again after dinner, I decided to not use the product heavy as I only had 8ml left and had over 70% of the car left to coat. I was still using an X of product for each section though. What I did this time around was not wipe of heavy….I was spreading it around for 30 seconds. I never stopped once to let it cure for 60 seconds as recommended. Nor did I go over the high spots with the applicator after 60 seconds. I just worked everything I could for 30 seconds, spread out as much as I could, spread the heavy areas to cover the not so heavy areas and then wiped. From start to finish was around 45-55 seconds for each section.
I thought I had done well as I could not see any product left behind after wipe off.
Car looked great and I called it a night:
Next day in the daytime, I took some pics and did not notice anything in the sunlight. I was happy. Later in the evening I had to run some errands and the sun was setting. I stopped the car to admire it and take some shots….This is where my jaw dropped….and not in a good way. I had streaks and residue marks everywhere!
Passenger front door, along with the drips:
Passenger rear door, not as bad but its there if you look between the handle and the orange glow:
Passenger C pillar / beltline. Look right above the beltline and you will see a dark haze:
Can’t see it. Okay, here it is zoomed in from a different angle. Right above the beltline we can see what looks like areas where the LC applicator reached before going back down.
Hood, right in the centre, dark spots:
I did not see the driver side as that was away from the indirect light of the sun and I could not see much. I could not see much on the roof either.
A point to note: The roof was done quite heavy and wiped of wet, so was the driver side front door. This was before Mr. leaky syringe.
Overall Impressions:
The product is nice and I would have had better results if I had continued working heavy and wiped of wet. This is my mistake. I got carried away after reading some replies to my other thread where people waited. I also read a thread by Mike Philips where he said most of the product will flash away by the time you start wiping/buffing and this is what I continued to do. I should have followed my gut and Andre’s advice of wiping wet as he was honest and told me about his experience working outdoors. Not a planned application in an air conditioned clean room, where there is almost zero error. Do the reviews in the real world, then we will see what happens.
Application:
Application was pretty cool. By this I mean, When buffing off, it was initially grabby. After about 30 seconds, it starts to feel slick. After about 1 min, when doing a final buff the towel just glides on the paint, i.e. Super Slick.
i would appreciate it if these coatings had more instructions and real world reviews, in real world surroundings and not temp controlled garages. I know thats a lot to ask as its a coating, but if you go by the claim that "even a first timer will find this super easy" - it would nice to take into account that many of the "first timers" dont have temp controlled garages, or any garages for that matter.
Yes,but in a 30cc syringe to not get stuck in the middle with a leaking syringe, lost product and working on fumes. I would work it heavy and wipe of wet due to my "Real world" conditions. Also, I would probably only use it in winter. Our winters are 20-25 degree celcius ambient temps (68-77 degrees F)
Yes. If you, like me , work in the real world, with heat and humidity, do yourself a favour and apply thick and wipe of wet. DO NOT LET IT FLASH completely. ☺
Thank you all.
Please do not take offence to anything above. This was an unbiased and very honest review.
Re: My unbiased (nightmare) review of PBL V2 Diamond paint coating and Wolfgang Uber Ceramic
Wow...very strange results. I had the exact opposite experience with PBL. It seemed to have plenty of working time, and even after I did an entire car, I found some high spots I had missed in the sun, and they wiped off with no problem. It seemed to be very forgiving.
As far as Uber, I found this a little trickier to use, for the some of the same reasons you mention, I really was struggling to gauge whether I was using to little, enough, or to much. I didnt have any problems with streaks or leaky syringes though. And on both accounts I got perfect, streak free results.
I am going to be applying the McKee's 37 paint coating, which is similar to the PBL coating. Hoping I don't run into similar issues. One big difference will be the temp. For me, the temp will be in the 60's to low 70's in my garage.
I agree, very strange results indeed. However, I feel weather and product drying too fast were my major problems.
I just could not get it to work....I have no words as to why :/
If your garage is closed completely you should be fine I think, especially in that weather.
What I would suggest is to get some very light finishing polish by hand and going over the high spots. It seems to remove them. As for your girlfriends car, try some PBL detailing spray over the high spots, they do come off because they're not fully cured yet and but the detailing spray has the same solvents they use on the coating.
I don't follow directions well .... so my results and techniques are completely different than suggested. What I will offer is that with Uber, I had no issues whatsoever. After polishing, and a wipe down, I applied it with syringe to foam applicator to finish in straight lines. Very little overlap. I stayed reserved and did not over apply. You could see it flashing within a couple minutes. About 6-7 minutes after a panels application, I had my son wipe down the panel very lightly with a MF towel. Absolutely no streaks, high spots, or issues. I then let it final cure in the garage over night. We live in South Florida and average heat even in morning is 80's with high humidity.
I did learn from using the original Opti-coat coating many years back. Once you have a high spot and have to either live with it, or polish it out, you learn to control excessive product and large overlapping.
Did a couple of cars with this in the past few weeks. Flashes pretty quick, apply the wipe off...about 80 degrees inside garage.
I would die if I tried to put anything on my car when it is 100 degrees and 80 percent humidity. I just won't even try when conditions are that excessive. I have washed my car in 95 plus degree temp and high humidity and I soaked through three shirts with sweat. I try to wait until conditions are cooler to do any type of detailing.
Last Post: 09-14-2019, 07:10 PM
By StangFan25 in forum Product Reviews
Last Post: 05-11-2016, 09:45 PM
By Goodylax in forum Product Reviews
Last Post: 04-02-2016, 06:21 PM
By Justin at Final Inspection in forum Show N' Shine
Last Post: 12-03-2015, 05:46 PM
By Justin at Final Inspection in forum New Car Care Products
Last Post: 10-31-2015, 06:10 AM
