FLEX PE8 Kompakt
I got this a few days ago from AG and I love it! It's perfect for motorcycles,jet skies,headlight restorations, and taking out scratches on any type of vehicles. I highly recommend this mini rotary polisher! You can go from a 1" bp to 3" bp. I'm not sure if you can go above the 3" bp I haven't tried if anyone knows if it can be used with higher bp please let us know!
Re: FLEX PE8 Kompakt
I've been dreaming of the Kompakt for quite a while now. Can't wait to be able to afford it.
Wondering if there are MF pads for this .
I hate mine, I rarely if ever (like never) use it over my Rupes Mini. For me it was a total waste of money.
2019 Nissan Rogue SL
I like the PE8, it can get into areas that the Mini cannot.
Congrats! Thanks for the mini review.
I'm hoping one day to add it to my collection. For the time being I am using the PE14.
Would you be interested in parting with it?
I am beginning to agree with you
As far as running larger pads with the PE8... I ran it for about 10 minutes with a 5.3" wool pad and the tool became too hot to hold on to. I do not think the machine will tolerate larger pads without failing in short order.
Beware of those giving suggestions without evidence of their results.
As an F.Y.I. - You asked this question in another thread to which it was answered:
A2S wrote:
I'm asking if I can use the flex to correct my whole hood i'm asking that because it's such a small rotary yes I know I asked about for smaller spots but I'm wondering if they can also do larger
PG Wrote:
Short answer, you can... Nothing and no one is going to stop you, except you'll be doing it at the risk of burning your clear coat.
FLEX PE8 Kompakt Rotary Polisher, motorcycle polisher
- The FLEX PE8 Kompakt Rotary Polisher is a purpose-built polisher designed specifically for small, intricate body panels.
- Designed for use with pads ranging from 1 to 3 inches in diameter.
Your asking if you can use a PBM (Purpose Built Machine) to do something other than it's intended design. The problem lies in the fact that it's a direct drive rotary style tool which is not dual action. The second problem is the heads are only designed for 1 to 3" pads, the smaller the pad, the more heat you will generate.
If you have a DA (PC 7424) that is what you will use for the majority of the vehicle. Preferably 5.5" Pads with a 5" backing plate. Switch to a 3" backing plate and use 4" pads for the tight areas. I have a three DA's, GG15 and PC's, and one of the PC's has a 3" backing plate for the smaller tight spots, I use the GG G15 on the majority of the vehicle.
My suggestion is to pick up Mike Phillips book "Complete Guide to a Show Car Shine". He dedicates several sections (chapters) to DA, comparing various DA's, backing plates etc... to Rotary with various pad combinations and how to use them all. Mike Phillips Detailing Books 3 Pack
It's not worth the trouble of selling it. LOL. For what it would cost to ship it you'd be better off buying a new one and getting the warranty.
I don't know why anyone would use the Kompakt for polishing a hood or run a 5 inch + pad on it. It's called Kompakt for a reason. To use in small and hard to access spots.
I want to get one specifically to do headlights restoration. I'm currently using a drill. Does the job but very unpractical.
By Trevine in forum Auto Detailing 101
Last Post: 05-24-2019, 08:59 PM
By OMGClayAiken in forum Auto Detailing 101
Last Post: 08-25-2018, 12:40 PM
By hdez in forum Auto Detailing 101
Last Post: 04-23-2017, 06:30 PM
By kwwhite1 in forum Flex Polishers
Last Post: 03-11-2016, 02:03 PM
Last Post: 12-03-2014, 01:41 PM
