Re: Review: Wolfgang Exterior System: Polish Enhancer, Deep Gloss Paint Sealant 3.0, and Deep Gloss Liquid Seal
Originally Posted by StoleIt
Quick Update:
Not sure if this is a first rinse issue or if some sealants just have a high friction to them? Maybe someone with more experience can chime in? I will also update again after the next full wash, I hope the friction will improve after a second wash.
I use WGDGPS on my truck and top it with liquid seal after every wash. I don't have any problem with the water sticking to the paint.
Where does Liquid Seal fall in between WG 3.0, WG Spritz Sealant, WG Detailing Spritz, and WETS. I have all these products already, but not the Liquid Seal.
I don't know what's the main use for this product, when I have all these?
Just tossing this question out there again in case anyone knows.
Thank you and have a great weekend all!
Ray
Liquid seal is a dedicated sealant, but its spray and wipe product like Blackfire Crystal Seal or Ultima Paint Guard. Its not a typical post wash booster like spritz sealant or detail spritz, its an actual dedicated sealant with a good 3-4 months durability. Been using it for years. The order of products in terms of protection would be Deep Gloss Paint Sealant, Fusion, Liquid Seal, Spritz Sealant, Detail Spritz.
Back to the full-time grind.
I use it as a drying aid
you're using liquid seal as a drying aid? seems like you can save some money especially since its a dedicated sealant and you're just diminishing results after a while.
I know but I got 16 oz of the stuff and only use 1 or 2 sprays per panel which is like a fraction of an ounce per car.
Great info thank you!
Car enthusiast, here to learn. 2015 Audi RS7.
I noticed the same thing about water not flying off the paint with liquid seal. Pretty dissapointing to see. I've used it on 4 different cars and same results. Maybe I got a bad batch? I just assumed it was the characteristic of liquid seal, so o stopped using it.
Liquid Seal is not as aggressive with water compared to some other products. So rather than seeing tight beading that flies off while driving, you should notice it will have a tendency to sheet water more slowly at a fairly steady rate after a wash and rinse.
By Grifftech in forum Auto Detailing 101
Last Post: 08-04-2014, 10:08 PM
By RayBay30 in forum Wolfgang Car Care
Last Post: 02-01-2014, 09:06 PM
By fordf150xlt in forum Wolfgang Car Care
Last Post: 08-30-2013, 11:08 PM
By TroyScherer in forum Product Reviews
Last Post: 11-21-2012, 07:14 PM
By TOFAST4U2C in forum Auto Detailing 101
Last Post: 10-17-2012, 05:02 AM
