I wanted to create a demo headlight I could show people and thought great time to bring a new product along for the ride and put it to the test.
I found an ebay special set of headlights for my test subjects. All the pictures below will link to the full size versions in my gallery.
Our test subject today features a very cloudy lens, OEM UV protection broken down, long surface scratch bottom right corner, and heavy pitting.
McKee's 37 All In One Headlight Restoring Polish being an all-in-one I didn't expect miracles. These are worse headlights than I would even waste my time not wet sanding, but for the sake of testing and results let's see what we can do here.
Before Shot
5 Passes of McKee's 37 All In One Headlight Restoring Polish
Meguiar's red foam cutting pad was used on 3" pneumatic rotary, product worked 5 passes.
On the lower part of headlight where the OEM UV coating wasn't broken down it did return a good amount of clarity. It "darkened" the look a little compared to what Plastx does. After thorough wipe down it left something on the lens that Plastx does not, almost a little oily. If the lens is to be coated with a UV protectant (not just a UV lotion/spray) I highly recommend a stripper/cleaner before coating. At the very least an IPA wipe down should be done.
As an all-in-one I did not expect the pitting and surface damage to be leveled out, but I was very impressed with the amount of correction on the surface scratch on the lower right. It did about a 75% correction. Happily impressed with that cut ability.
Deep Clean and UV Protectant Middle Section
Left section is before section. Middle section McKee's 37 All In One Headlight Restoring Polish followed up with Meguiars Headlight Protectant. Right section was further deep cleaned with Meguiar's Mirror Glaze 17 Plastic Cleaner.
Right Section Wet Sanded, Sectioned Again
The entire right section (the entire part of light in this picture), was wet sanded 800/1500 grits with 3" pneumatic DA then 2000/3000 grits by hand.
The center tape was added and on the right side McKee's 37 All In One Headlight Restoring Polish was used with a B&S 3" hex orange cutting pad, 4 passes. Then again with Meguiar's 3" foam polishing yellow pad, 4 passes.
Close up McKee's 37 All In One Headlight Restoring Polish 2-step
Close up with bright light showing 3000 grit sanding marks polished out with B&S 3" hex orange cutting pad, 4 passes. Then again with Meguiar's 3" foam polishing yellow pad, 4 passes.
I found with using the orange pad it did not finish off as clear as I wanted. There were still enough DA cutting marks left that another section pass with a softer pad was beneficial to finishing off clearer.
Note: Far right grunge is inside lens damage.
McKee's 37 All In One Headlight Restoring Polish After Wet Sanding
Before and After of 3000 grit sanding marks. Left side 3000 grit sanding marks. Right side polished out with B&S 3" hex orange cutting pad, 4 passes. Then again with Meguiar's 3" foam polishing yellow pad, 4 passes.
Thoughts: Maybe with some more fine tuning of process the 2nd step could be eliminated making it a true one step product. The end results were about 80% correction. Very respectable for an all-in-one product but since I had to 2-stage it anyways, it won't replace the M105/M205 combo that does finish a tad bit better ~90% correction.
Left side 3000 grit sanding marks, right side after McKee's 37 All In One Headlight Restoring Polish.
After Shot Meguiar's M105/M205
Entire wet sanded side polished with M105 using B&S 3" hex orange cutting pad with pneumatic rotary, 4 passes. Then polished with M205 using Meguiar's 3" foam polishing yellow pad, 4 passes.
Using the same pads, pressure, passes as McKee's 37 All In One Headlight Restoring Polish to give an example of difference. The M105/M205 can be seen here finishing off better with about a 90% correction.
Spar Urethane UV Protectant Applied
Spar urethane, mineral spirits 1:1 applied
After Shot - 3 sections
Left - untouched
Middle - Polished with McKee's 37 All In One Headlight Restoring Polish, Meguiar's Headlight Protectant applied.
Right - Wet Sanded, Polished with M105/M205, Spar Urethane applied.
Comparison Before and After
Top headlight showing the before state. The top headlight's OEM UV protectant was not as badly degraded as the bottom one but still shows a great before/after of the different products and techniques.
Some of the Tools/Pads Used
Chicago Pneumatic CP7200S 3" DA, Harbor Freight 3" Pneumatic Rotary.
B&S 3" orange hex cutting pad, Meguiar's 3" foam polishing yellow pad
Video
Who doesn't like video? Hopefully capturing the differences in correct-ability of the different products and techniques described above.
Thanks for reading/watching, hopefully this gives you an idea of what is possible and what you can expect at different levels of usage
I welcome any questions or constructive criticism on my usage and results with McKee's 37 All In One Headlight Restoring Polish.
Cheers!
-Matt
