Re: Review - NEW BLACKFIRE All-In-One Trim & Tire Protectant
how long it will last for daily use ?
Originally Posted by Marc08EX
Amazing review Mike! Thanks for taking time to write this.
The concept of this product is a great idea!!!
I agree that there's just no way to clean the tires without dragging the hose or some type of sprayer when doing rinseless/waterless to the paint. An AIO that cleans, shines and protects tires and rubber surfaces?! SIGN ME UP!!!
Thanks for providing some guidance on the proper way to use this product. I was already thinking of using a foam applicator pad for this product but I'm thankful I read your product direction of using a MF or terrycloth applicator and scrub the surface with a little passion.
Great job Nick & PBMG! I'm sure this product will be a home run.
Maybe true for trim, but for tires I've been using Mothers Black to Black in the bottle (not can) no water or hose needed. It works fantastic, and makes my rinse-less process closer to flawless. With that said I'm definitely going to be ordering this. If it can clean as well as the Mothers and works on trim it will be a go-to for me.
I have to believe Mothers will clean better. I often just reapply the same dressing during a maintenance wash and it can hide tire brown, etc anyway.
Even when I am doing rinseless, I have 3 choices:
1. Strip and dress with Mothers then tire dressing of choice
2. Clean/dress with Poorboy's Bold n Bright. Blackfire is now another choice and like to see if it is more durable
3. Redress with the same dressing
Originally Posted by Nick@Autogeek
I'm thrilled this is finally available!
When will samples be available.???
I have purchased alot of products they do not live up to my standards,
and end up dumping.
Mike !!!
Mid-Michigan
Tri-Cities
I know we shouldn't/don't use tire dressing on rubber floor mats. Would that still hold true with this new product?
McKee's 37 Product Support
Originally Posted by conman1395
Have you guys never tried Mother's rinseless tire cleaner? It's not difficult at all and I've used it to coat tires during the winter when no hose was available.
I sure have, and it works great. The main reason I wash my car using the rinseless method is time constraints. Having a product (All-In-One Trim & Tire Protectant) that cleans AND shines the tires in one step saves me a ton of time. Plus, if I'm concerned about deep cleaning my tires (which you should do every once in a while), I'll wash the car the conventional way and use DP Tire Cleaner & Restorer.
Simply put, I have zero interest getting on my hands and knees and going over my tires twice (cleaner and then protectant) when I perform a rinseless wash. BLACKFIRE saves time and effort.
and end up dumping.
No samples will be available of this product, at least for now. You'll just have to trust myself, Mike Phillips and the fact that it's another quality product from PBMG.
I tend to err on the side of caution and say NO. You can try it for yourself, but I don't recommend it.
I love the Mother's rinseless,but I am all over this product at some point. Talk about a time saver!
Sounds good!
Does this product buff easily off paint if you get some on it while using?
____________
Originally Posted by Mantilgh
Sounds good!
I tested that today on very fresh BFWD, buffs off very easily if you have any overpay or a smear.
Thank you, makes it sound even better.
____________
Last Post: 07-27-2016, 06:46 AM
Last Post: 06-26-2015, 11:07 AM
By Jaretr1 in forum Product Reviews
Last Post: 06-22-2015, 05:44 PM
By Audios S6 in forum Product Reviews
Last Post: 06-22-2015, 10:03 AM
