Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Super Member Rsurfer's Avatar
    Jan 2007
    14,100
    Re: Using Solution Finish to Restore Running Boards - 2018 Chevy Silverado
    Solution finish is way ahead of the times by using graphite. Its milled graphite that gives it that black color, same as graphene.
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    Quote Originally Posted by Jacob Harrod AUTOCLEAN View Post
    What was your ratio of IPA to distilled water? For stubborn trim I typically use Meguiar's APC diluted 4:1.
    I may start using your ratio of IPA/distilled water or perhaps Meguiar's Surface Prep M122 as a secondary cleaning step.
    To be completely honest, I forget. Lol
    I mixed it up a few years ago after reading about it here on AGO. I really want to say 2:1?
  3. Likes Jacob Harrod AUTOCLEAN liked this post
  4. #13
    Aug 2020
    44
    The big difference is that the PBL (and any ceramic coating) will protect the finish and restore it to its natural color. The Solution Finish is going to turn stuff black, because it's full of black pigment.
  5. #14
    Quote Originally Posted by TMQ View Post
    OK...everyone says get trim clean.
    So what do you use the get the trim clean?
    Tom
    I think machine scrubbing is the best option when possible.
    How to do high quality production detailing - Your largest market!
    Machine scrubbing plastic cladding
    Demonstration: How to apply and work in Solution Finish
    Using a black wheel and tire microfiber towel to wipe off any excess.
    Removing the painter's tape....
    Boom! There it is...
    And here are the results.....
  6. Thanks TMQ thanked for this post
    Likes Thomkirby liked this post
  7. #15
    Quote Originally Posted by MarkD51 View Post
    I wonder how this one would fare in a head to head comparo against Solution Finish?
    Pinnacle Black Label Ceramic Trim Restorer
    I have some of this on hand, but never used it.
    I'm hoping that the day I do eventually use it, that it is still usable, and hasn't expired past its use date?
    Both do the same thing except the PBL Ceramic Trim Restorer has a built-in ceramic coating. So you don't need to top it with a dressing or a coating.
    The Solution Finish is simply a pigment or a dye, you don't have to top it but topping it will help to lock it in. Even Chris West recommend topping it.
    Quote Originally Posted by muaddba View Post
    Yup.
    I've obtained great results using both.
    The large bottle size for the Solution Finish when you have a LOT of real-estate to cover is a good value.
    The results and longevity of the PBL Ceramic Trim Restorer is also a good value. Perhaps use one and the top with the other?
  8. #16
    Super Member Jacob Harrod AUTOCLEAN's Avatar
    Mar 2020
    El Reno, Oklahoma
    754
    I'll give it a try brother!
  9. #17
    Aug 2020
    916
    The big question, does the Finish Solution wash away?
  10. #18
    Quote Originally Posted by DUBL0WS6 View Post
    My guess is anything topical will with some soap and water. What penetrates into the plastic will be a lot more stubborn to remove.
    This is why the owner of Solution Finish, Chris West states that after you use Solution Finish - then apply your favorite dressing or fill-in-the-blank to seal over it.
    Makes sense to me. And a good product would be anything that water-proofs the surface.
  1. What to use on running boards?
    By jackb88 in forum Ask your detailing questions!
    Last Post: 06-02-2018, 08:34 AM
  2. How to restore paint on a 1984 Chevy Silverado
    Last Post: 10-13-2015, 07:26 AM
  3. Truck Running Boards Restore
    By glh17 in forum Auto Detailing 101
    Last Post: 08-28-2014, 10:46 AM
  4. running boards
    By bonedr in forum Auto Detailing 101
    Last Post: 02-21-2014, 04:53 PM
  5. Solution Finish vrs Tuff Shine Black Restore Test
    By swanicyouth in forum Product Reviews
    Last Post: 10-28-2013, 08:45 PM
