Results 11 to 20 of 34
    Mar 2019
    49
    Re: 1976 Corvette Original Single Stage Paint - Paint Correction and Waxing
    I had a 1975 Bronze colored 'Vette that I bought from my brother who purchased it new. He sold it to me and purchased a 1965 yellow coupe. My '75 was a dog, I think it had around 195 hp. My '19 'Vette GS has 460 horses
    Rich
    Attached Thumbnails Attached Thumbnails 1976 Corvette Original Single Stage Paint - Paint Correction and Waxing-img_4416-1-jpg   1976 Corvette Original Single Stage Paint - Paint Correction and Waxing-img_4435-jpg
    Super Member JDGolden's Avatar
    Mar 2013
    Michigan
    1,516
    Incredible turnaround. I agree with Aaryn, and probably everyone else, but give me the original car. Original paint is only original once.
    2017 Jeep Wrangler Unlimited Rubicon
    1999 Camaro Z28
  3. Likes Aaryn NZ liked this post
  4. #13
    Nov 2016
    253
    The polish is actually the BLACKFIRE One Step - I apply to the entire car and let it fully dry before removing.
    Mike do you do this with most of your AIO's or is this unique to One Step?
  5. #14
    Super Member Jacob Harrod AUTOCLEAN's Avatar
    Mar 2020
    El Reno, Oklahoma
    754
    Re: 1976 Corvette Orignal Single Stage Paint - Paint Correction and Waxing
    Mike,
    I'm with craigv. How come you didn't use the Meguiar's #7 approach this time around? Also do you have an article on how to select the correct products and pads to correct the paint? What would you have done had there been coloration on the clay? Is there a cure time for the BlackFire One Step, and could you add another layer of protection with a product like Beadmaker? I noticed that you used the Tornador air gun as a pad cleaning tool. That's a slick trick! Let me just say that the paint looks absolutely fabulous! Any response you can give is much appreciated in advance. Take it easy Mike, and keep on shining!
  6. #15
    Super Member theamcguy's Avatar
    Dec 2007
    Fayetteville, NC
    260
    Mike, interested in that question as well why was Megs #7 not used? Very interested as well as to how you restored the tires.
    Bill Strobel
    Owner Independent Towing & Repair
    Fayetteville, NC
    Do It Right or Don't Do It At All
  7. #16
    Mar 2020
    El Reno, Oklahoma
    754
    Cool Re: 1976 Corvette Original Single Stage Paint - Paint Correction and Waxing
    Quote Originally Posted by theamcguy View Post
    You know I did think about it some. Perhaps the paint just wasnt in a condition where it needed that step. I mean I didn't see a lot of if any oxidation. Plus the paint was thin as well so perhaps it could not hold up to the additional step of Meguiar's #7. There were mostly just scratches and swirl marks, which compounding would remove no problem. Did you see that one patch? It was really scratched up.
  8. #17
    Super Member 2wookies's Avatar
    Jul 2015
    367
    Quote Originally Posted by Red&BlackJacob View Post
    Mike,
    I'm with craigv. How come you didn't use the Meguiar's #7 approach this time around?)
    I thought for sure he was gonna do this.
    Solid 10 footer results.
  9. #18
    Quote Originally Posted by craigv View Post
    Impressive result Mike. You are a magician with a buffer in your hands.
    Thank you. It was nerve-wraking buffing out this car simply because of all the thin spots. But it was
    A: Compound it.
    B: Repaint it.
    I could as a couple of local restoration shops what they would charge to re-paint this car the RIGHT way, and by the "right way", I mean, do whatever it takes to get the body panels and paint right. Never mind rebuilding any of the mechanicals, just the paint.
    My guess would be in the range of $30,000.00
    And for a lot of people, myself included, before I dumped even half that into a paint job I would do what I did, that is buff it out. Cross your fingers, use great abrasive technology and then be damn careful.
    The paint looked pretty old and hammered. Surprising that you used a compound. You are more brave than I would have been. I would have bailed and just used Blackfire One Step twice. Just kinda snuck up on it.
    That was the original plan, JUST use BLACKFIRE One Step. This would be a very safe approach. I tested the BF One Step on the passenger side roof panel and it simply didn't remove enough of the damaged paint to make a "wow" difference. In fact, if all I used was the BF One Step, it was going to look like shiny dull/cloudy/whitish paint. In other words, it was still going to look like crap.
    The 2 pads in the back left you see in this picture, these were my Test Spot pads using only BF One Step. One is the RUPES wool polishing pad the other a LC Hybrid polishing pad. Neither did enough correction to make the kind of before and after difference you see in the after pictures. I tried the least aggressive approach, I HOPED it would work - but it simply wasn't enough.
    I have seen you use Meguirs #7 Glaze before on that condition of paint to give the paint some nourishment. Why not this time?
    Good question. I get this question a lot for different projects I tackle with either original paint or antique paint. I'll answer below because others are also asking.
    Lastly, I see you used my favorite lubricant to clay with. Sonax Glass Cleaner. Love the dual role it plays on the paint. Lubricate and CLEAN the dirt and grim off the surface.
    Yeah it's one of my favorite products. It's truly a great glass cleaner but I use it as a rinseless wash and a waterless wash. When using as a rinseless wash I simply dump half a bottle into about 3 gallons of water. I did this for the 1967 Camaro convertible for both the vinyl top and the paint, glass and chrome.
    Review: Machine applying RaggTopp Vinyl Cleaner and Protectant - 1967 Camaro Convertible
    Click this link and I show how I used the SONAX Glass Cleaner as a wash.
    Mike Phillips - Rinsing without running water
    As always....thanks for your time and efforts to inform and educate myself and the car detailing community.
    Craig
    Thank you, I'm always thankful to have a job I love.
    Just to comment, we've tried 2 TV shows to showcase car detailing, and the one thing I always noticed about them is that unlike all the other "Car Guy" TV shows - none of them ever have a platform where they share their knowledge and also answer questions for their audience. For example, name one Car Guy TV star and include the link to where you can go to ask them questions and get their answers? Or read their articles, reviews or write-ups? Maybe that's why the shows didn't make it.
    Mike,
    I'll answer this in a dedicated reply, not this multi-quote reply. Good question and as I shared above, I get this question a LOT when it comes to working on original and/or antique paint.
    Yes. This recent article answers your question, but not with specific product recommendations but instead, a big picture point of view. The key when working on car paint is to always use GREAT abrasive technology. If you use crap for products you'll get crap for results.
    The two reasons WHY you should always do a Test Spot before buffing out any car
    And anyone reading this into the future, if you haven't read this article, I recommend it.
    Abrasive Technology - THE most important factor when it comes to polishing paint
    There was discoloration. It's the color green and it's dead paint coming of the car, just not tons of it.
    Here's a single stage paint Bronco I detailed back in 2004, just 16 years ago, look at the amount of paint coming off the Bronco and onto the clay.
    1986 Ford Bronco II - Extreme Makeover
    Before
    After just one half of the hood.
    Back in 2004 - Nanoskin towels had not been invented yet. All we had was clay. After claying the Bronco the clay was so contaminated it was thrown away.
    The cure time for BF One Step is the same for ALL products. After application and wipe-off, wait for a WINDOW OF TIME for 12 to 24 hours before disrupting the finish. Give whatever Magic Voodoo Juice is in the product the time to do it's thing, whatever it's "thing" is,
    Polymerize, Bond, Crosslink, Hydrogen Bond, Set-up, Dry, etc.
    And yes you could do what's called Topping. This article dates back to 2011, that's 9 years ago as I type today.
    Topping - Definition - How to Top also called Topping
    I wouldn't use a product like the Beadmaker though, I would use something more substantial like the BLACKFIRE BlackIce, which I have shown as a topper for the BF One Step. But any NON-CLEANING wax or sealant could be used including SONAX PNS.
    While the Tornador Blow Out Gun is great for cleaning microfiber pads I would never use it to clean foam pads. I don't use a lot of micorifber pads because I don't like how they feel when buffing and most of the time they inflict their own scratches called micro-marring. I've explained this hundreds of times n this forum but here's the short version.
    Fibers are abrasives
    On soft and even medium hardness paint - each one of the fibers in a microfiber pad will CUT the paint leaving tiny scratches in it and when using any brand of orbital polisher, these tiny scratches are called micro-marring.
    It's okay to micro-mar the paint if you're going to do a follow-up step using foam, (uniform texture, not individual fibers), but if you're NOT going to so a second step - then you're leaving micro-marring in the paint.
    I think I recently posted somewhere I've been using microfiber pads since before the world knew about them so it's not that I'm not WISE to their capabilities, I just prefer to buff with foam. And I can really go DEEP on this topic if anyone wants me to.
    See this article I wrote just a few weeks ago and specifically post #2
    Fibers are a form of abrasive - Foam Pads vs Microfiber Pads by Mike Phillips
    Thanks for asking your questions, I'll answer about the #7 below.
    Good question - I'll answer below.
    Ask and you shall receive...
    Review: 303 Multi-Surface Cleaner as a Tire Cleaner + 303 Protectant as a Tire Dressing by Mike Phillips
    The above is correct.
    I'll post in my follow-up why I didn't use #7 for this project.
    Thanks for all the great questions....
    Like I always say, the opportunity to work on any car with the original antique paint is RARE.
  10. Thanks Jacob Harrod AUTOCLEAN thanked for this post
    Likes JKDesign, Jacob Harrod AUTOCLEAN liked this post
  11. #19
    More....
    Here's the short answer to the question about why I didn't use the #7 Rub Down Technique for the paint on this car.
    It didn't have chalky oxidized paint.
    The #7 Rub Down Technique is for a car that has the original, antique paint that has turned chalky. The chalkiness is oxidation.
    A hard shine
    Yes this paint was oxidized but it still has a hard shine to it. This is a picture I took after the car arrived and BEFORE I did anything to it. See the hard shine to the surface?
    The paint is NOT chalky. In fact, the surface was almost case-hardened with time. There was light oxidation, you can see a little green paint came off the car and onto the clay bar, but there was not tons of green paint i.e. oxidation coming off when I clayed it.
    The paint was simply aged, stained, spotted and filled with swirls and scratches.
    The #7 would not have done anything to bring the paint back to life so I first tried the very safe BLACKFIRE One Step and when that wouldn't cut through the years of hardening, I resorted to the Pinnacle Advanced Compound.
    I guess it's a judgement call as to when to use the #7 technique or not and the judgment comes from years of experience buffing out just about everything under the sun.
  12. Thanks JKDesign, Jacob Harrod AUTOCLEAN thanked for this post
  13. #20
    Continued.....
    1924 Model T
    My friend and alumni student of my 3-day class sent me this picture yesterday. He's going to try to bring it by for me to take a look at.
    I will test the paint to see if it can be saved or if it's past the point of no return and if the pigments have become unstable.
    I explain this in my how-to book,
    The Complete Guide to a Show Car Shine Paperback Book by Mike Phillips
    And also in these articles,
    Category 12 - Past the point of no return by Mike Phillips
    Past the point of No Return - Some paint just cannot be saved
    Here's what I'll mostly be looking for,
    Paint Condition Category #9 Unstable
  14. Likes Jacob Harrod AUTOCLEAN liked this post
  1. Pictures: 1972 Corvette Stingray - Original Single Stage Paint - Autogeek Extreme Makeover!
    By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
    Last Post: 03-19-2019, 08:24 AM
  2. Replies: 6
    Last Post: 06-27-2017, 07:32 AM
  3. 1972 Corvette Stingray - Original Single Stage Paint - Autogeek Extreme Makeover!
    By Mike Phillips in forum Wednesday Night Detailing Classes - Info & Dates
    Last Post: 07-07-2016, 03:33 PM
  4. Replies: 40
    Last Post: 04-05-2016, 01:41 PM
  5. Replies: 18
    Last Post: 03-09-2015, 02:53 PM
