04-30-2020, 01:21 PM
#121
04-30-2020, 03:04 PM
#122
Re: Review: Wolfgang Uber Ceramic Spray Coating
If you want a strong panel wipe, take a look at the GTechniq Panel Wipe or get some Mineral Spirits.
Mike, you would recommend this Gtechniq over Gyeon (which I see you recommend recently) or CarPro Eraser?
05-01-2020, 05:00 AM
#123
I have Prep-All here at the AG Garage. Don't use it much as it really stinks and I'm not one that's bothered by foul odors but this stuff reeks.
Thanks Mike
Over here Mineral spirits can mean Mineral Turpentine?
Will prepsol type product work other than smell. This is just as a test panel?
05-05-2020, 11:08 AM
#124
I have re-read this thread and have a question that I don't see has been addressed. I applied the Uber spray Ceramic on my black TransAm 5 days ago. She had to sit out for 2 days while I worked on my Daughters Mustang so she accumalated dust/pollen and then was rained on, so I washed it with WG Si02 coating wash (great product).
My question is, can I apply another coat of the Spray Ceramic?
05-05-2020, 11:28 AM
#125
My opinion: if you hadn’t used WG Coating Wash and it’s only been a few weeks (so not much embedded dirt or contaminants in that time) then yes, definitely.
And I would still do it after using the coating wash. These are both WG ceramic products, they should use similar polymers, SiO2 formulation. Chances are they will play well together and feed off each other. Plus, the CSC bottle holds a ton of applications so why not use it and play around. I can’t imagine anything ‘bad’ coming out of this.
05-05-2020, 11:39 AM
#126
Thanks for that quick response. This stuff is so darn quick and easy to apply and remove its crazy!!
05-05-2020, 12:06 PM
#127
So are multiple coats for durability better than just one? Can it be applied over the WG Si02 Paint Sealant as well? Just thinking back to the days (like last year) when I would top off the WG DGPS with WG Fuzion and am wondering if the benefits of multiple coatings apply to ceramic products.
05-05-2020, 09:36 PM
#128
Differing opinions and none are probably wrong. I like two coats of anything for sure coverage. I don’t detail for money so I’m not trying to save every last drop of product though.
In my opinion, there’s potential benefits for topping SiO2 and Ceramic Spray in either order. I don’t know longevity of each yet but the sealant has had better behavior for me so it would be good on top... but on the other hand Ceramic Spray is so easy to apply and it’s behavior is still good, so it would be a good topper just to apply whenever. PBMG products always have good synergy so my bet is that you can mix and match these things to what you are looking for and they will most likely leave you with a smile.
05-05-2020, 10:44 PM
#129
As far as panel wipes go, Gtechniq Panel Wipe is much stronger and more significant than the Gyeon/CarPro twins. If you're trying to specifically tackle fresh products, Gtechniq will do a better job at this in knocking them down. After polishing paint I still feel Gyeon/CarPro are effective, and definitely paint safe, so there's a balancing act going on in terms of strength and safety. Gtechniq feels like I could get into trouble if I'm not careful with how I'm working with it, but I need to pull it out more and see if I can get trouble to pop up negligently. This is where Prep-All shines, because I haven't been in a situation yet with Prep-All where I felt it was unsafe on the paint, even in negligent circumstances. More power than Gyeon/CarPro, better on/off application than the other ones especially Gtechniq, and by far the best price of the bunch for the gallon. The main issue with Prep-All is like Mike said, the smell is heavy solvent based. I've used much worse smelling, but I still like to wear my half-mask respirator with it.
Yes, you can definitely add a second application of the Spray Coating and this may ultimately be more beneficial than one coat. I'm working on testing this right now, on my front bumper I've added a second coat on half of it after my last wash, so I will check to see how this holds up compared to the single application on the other half. I'll be able to observe the first wash of the second coat tomorrow and report back.
05-05-2020, 10:53 PM
#130
@Loach, what is the unsafe potential you speak of for Gtechniq? Lack of lubricity, drying out paint, other?
Looks like I’m in the market for Prep-All.
By Loach in forum Product Reviews
Last Post: 01-08-2021, 12:56 AM
Last Post: 05-04-2020, 07:02 PM
By SgtMajUSMC in forum Product Reviews
Last Post: 08-26-2016, 03:59 PM
By Audios S6 in forum Product Reviews
Last Post: 06-09-2016, 06:58 PM
Last Post: 02-24-2016, 09:13 PM
Members who have read this thread: 8
