Page 10 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 91 to 100 of 162
  1. #91
    Sep 2013
    Re: Review: Wolfgang Uber Ceramic Spray Coating
    thanks,
    I should probably know this but I don't. Is there a way to contact Andre and ask?
    duplicate post. excuse
  2. #92
    Sep 2013
    OK,
    While the car is still clean and in the garage, do I need to remove the SiO2 sealant to install the Ceramic Spray Coating, and would that be just another panel wipe with WG panel prep or would I have to buff the "SiO2" Sealant
  3. #93
    Super Moderator Andre's Avatar
    Sep 2013
    Stuart, Fl
    167
    Quote Originally Posted by arthur1920 View Post
    OK,
    If you want install the coating, you would want to remove the paint sealant first. If it were me personally, I would do a fine cut polish just to ensure I removed the Paint Sealant completely. Just doing the paint prep, you wouldn't really know for sure if it got 100% off completely. A fine cut polish like Wolfgang Finishing Glaze would for sure 100% remove the paint sealant. Then just use the Paint Prep and proceed to do the coating! If you have any questions, you can also reach me at 1-800-869-3011 ext. 1244 as well.
    Autogeek R&D
    andre@autogeek.net
  4. Likes Thomkirby liked this post
  5. #94
    Sep 2013
    thank you, Andre.
    I will make a decision about this as soon as I can stop kicking myself in the ass.
  6. #95
    OK,
    Anytime you seal your car's paint with a wax or sealant, or use an AIO (cleaner/wax), you have basically just chose the path of NOT using any type of ceramic coating due to a bonding issue.
    if you want to use a ceramic coating, any form, then after any prep work (that does NOT include any product that "seals" the paint or causes water to bead-up), then chemically strip the paint and apply the coating per instructions.
    Chemically strip means to use a panel wipe or solvent.
    It's all about working clean and properly preparing the surface.
  7. #96
    Quote Originally Posted by Andre View Post
    Thanks for chiming in Andre, I know a lot of people love reading your insights about product useage and performance.
  8. Likes RamAirV1 liked this post
  9. #97
    May 2013
    351
    Would Meguiars glaze work in place of Wolfgang Finishing Glaze?
  10. #98
    Quote Originally Posted by bcgreen View Post
    No.
    Meguiars glaze is not abrasive - it does not work like Wolfgang Finishing Glase which is NOT a glaze but a fine cut polish.
    The WG glaze should be renamed (years ago)
  11. Likes PaulMys, RamAirV1 liked this post
  12. #99
    Sep 2013
    You agree with Andre, then? I must re polish the car to remove every bit of SiO2 sealant? Panel wiping wont do it?
  13. #100
    Yes.
  1. Replies: 48
    Last Post: 01-08-2021, 12:56 AM
  2. Wolfgang Uber Ceramic Spray Coating (Mini-Review)
    Last Post: 05-04-2020, 07:02 PM
  3. Wolfgang Uber Ceramic Coating Review
    By SgtMajUSMC in forum Product Reviews
    Last Post: 08-26-2016, 03:59 PM
  4. Review - Wolfgang Uber Ceramic Coating
    By Audios S6 in forum Product Reviews
    Last Post: 06-09-2016, 06:58 PM
  5. Review: Wolfgang Uber Ceramic Coating
    Last Post: 02-24-2016, 09:13 PM
Members who have read this thread: 9
