Re: How To Do a Test Spot
Top notch info as usual. I'm new to detailing for profit, and will "profit" from this info!
After you dial in your Test Spot, try this sometime... there are marketing reasons I list in the full article,
Knock out painted roofs first, then tackle the rest of the car...
Im the MAN
Quote:
Originally Posted by
dwlinc23
Doing a Test Spot is all about saving time and saving time is a huge part of increasing profitability.
:xyxthumbs:
Fantastic info Mike! Thank you!
Jomax
Another AMAZING article, Mike do you ever do detailing get togethers In the west?
I did when I lived in SoCal, we called them Detailing 101 and Advanced Detailing 102 and TNOG's or Thursday Night Open Garage all at Meguiar's Corporate Headquarters in Irvine, Californial. Did them from 2002 to 2009 then came to Autogeek.
shoeless89
Thank you.
Been teaching people to do a Test Spot officially since around 1993 when I started recommending it on the Usenet Newsgroups in rec.autos.misc
I think I document it here,
Test Spot - The story behind the story...
:D
I do a Test Spot on every car I work on unless I've previously worked on it and already have a feel for how the paint buffs. No exceptions.
Here's a 2006 Mosler I buffed out for Corvette Mike back in 2006, somewhere I have all the before and after pictures from the project but the only pictures I ever processed and put on the Internet were these 5 and they were to show the Test Spot.
If you look at the top of the driver's side fender you can see where I did my test spot after arriving to Corvette Mike's shop and setting up for the day.
http://www.autogeekonline.net/galler...hillips003.jpg
You don't have to tape-off a perfect square and in fact this will just use up precious time. I did this for the picture but to also show all the employees at the shop where I did the work the difference between before and after.
http://www.autogeekonline.net/galler...hillips001.jpg
I had to have a few of the mechanics at Mike's shop help me push the car out into the sun to get this sun shot. The sun was still low in the sky so it was hard to get it on the section I actually worked on. To get this shot I was actually leaning way over on the car shooting away from the car in order to get the sun's reflection as you see it in the lower, right hand corner. Even so you can see the paint was completely filled with swirls.
http://www.autogeekonline.net/galler...hillips002.jpg
I buffed out the entire car including rubbing out all of the louvers by hand using ScratchX. In this picture that's a machine applied coat of NXT I believe.
http://www.autogeekonline.net/galler...hillips004.jpg
Here's the finished work...
http://www.autogeekonline.net/galler...hillips005.jpg
The paint on this car was horrible in two ways.
1. It was completely filled with swirls and scratches.
2. The paint was incredibly soft and would scratch very easily. This is why it was filled with swirls and scratches, (probably from normal washing and wiping).
I found out the paint was soft and scratched easily by doing my test spot.
If you've never worked on the car in front of you, before you buff out the entire car with your first choice of pad and product, first do a Test Spot. Dial-in a process that works and once you've proven it works in a small section then all you have to do is simply duplicate the same proven process to the rest of the car and theoretically you should get the same results over the rest of the car.
It should only take you a few minutes to do your Test Spot and it can save you a lot of time and heartache.
jminrod
I'm hoping to start my car this weekend and had a test spot question. I have some bad scratches in my car.
1) Should I start somewhere other than the scratched area since the whole car is not scratched as much as that specific area?
2) I have 105 300 301 looking at picking up some 205 tomorrow. Should I start with the 105 for the test spot or should I just try the MF pads and the 300?
Do a Test Spot for each of the two types of areas.
Chances are good you're going to have to use a compound for the worst area and compound for the areas that are not so bad and that's because modern clear coats are pretty hard.
Also, M105 and D300 are SMAT product so you can stop at any point during the buffing cycle. With DAT product you're supposed to work the products till the diminishing abrasives have fully broken down, the subtle difference is with SMAT you can stop abrading paint when the defects are gone, with DAT it's possible the defects could be removed but you still need to buff to make sure the diminishing abrasives are not leaving their own scratches behind.
(Deep thoughts, deeper than most people care to get)
The M105 is more aggressive than the D300 so you can try the D300 first and if that isn't getting the job done then switch to the M105, both are very very good compounds.
jminrod
I have the Megs MF pads 5.5 & 3"
I also several colors of the lake country foam pads and a new porter cable xp. I have a Dodge Caliber if that makes a difference. Thanks for everyones help in getting this far. Can't wait to get started.
Great questions!
Key thing is to do some testing and make sure you're seeing the results you want and expect before buffing out the entire car. If you're not seeing the results you want then start a "new thread" to explain what's happening and our forum community will help you to tweak your technique and see you through to success.
Read this BEFORE starting, then you'll know what not to do and what to do from the very start.
DA Polisher Trouble Shooting Guide
:xyxthumbs:
***Bump***
Bump for anyone new to machine polishing...
I've been buffing out cars all my life and I ALWAYS do a Test Spot before buffing out any car I have never buffed out previously.
Here's an example from just this last weekend...
See the tape on the front, center of the hood? That's from doing a Test Spot...
New Menzerna FG 400 - One-Step Show Car Makeover
Test Spot = Menzerna FG 400 with the Lake Country 6.5" Hybrid White Polishing Pads on the Flex 3401
I did a Test Spot using a tape-line on the front of the hood and then inspected using my Brinkmann Swirl Finder Light and the results were a clear, high gloss finish that was silky smooth to the touch and all swirls, scratches, water spots and oxidation was removed. After confirming the combination of the Menzerna FG 400 with the Lake Country 6.5" Hybrid White Polishing Pads on the Flex 3401 on speed 6 was giving me the results I wanted I proceeded to buff out the entire car using this combination.
http://www.autogeekonline.net/galler...illips_003.jpg
Finished...
http://www.autogeekonline.net/galler...illips_041.jpg
:xyxthumbs:
Mike.Phillips@Autogeek
Just finished this very thing yesterday...knocking out the top.:props:
Hoytman
Cool Bill...
It's not a technique that a lot of people know about or think about but it works for me...
:xyxthumbs:
Just wrote a new article to answer a common question and sometimes problem when doing a Test Spot...
The LINE ---> How to avoid the line!
Something I've been meaning to write about but it's always just another item on my to-do list is how to AVOID the LINE when doing a Test Spot using a strip of painter's tape.
That is the line that separates the before and after results the YOU use to inspect and gauge your progress and results.
This line...
http://www.autogeekonline.net/galler...exVideo005.jpg
After using a strip of painter's tape for your test spot like this...
(and why it's so important)
http://www.autogeekonline.net/galler...TapeLine02.jpg
http://www.autogeekonline.net/nick/D...pot-redone.jpg
Answer coming up...
Here's the follow up...
Question: How to avoid the line!
Answer: Anytime you're doing a test spot, if it's just you're own car or even a customer's car, then buff to the side of the line, not directly on top of the line.
Why?
Because sometimes you can remove enough paint to actually leave a line in the paint that can be hard to buff out.
When I do these types of things for articles I'm trying to create a DRAMATIC "Before & After" picture showing the before and after results with a strong demarcation line.
Unless you "want" or "need" the picture then just buff close to the tape line, not directly on top of the tape line and you'll avoid creating a physical level difference in the paint that shows up as an actual "line" in the paint. (that can sometimes be hard to buff out).
Make sense?
So if you do a test spot and conclude it needs more work, do you make a second test spot or continue working the first spot?
Ebf2k
Great question! :xyxthumbs:
The answer is you do a test spot in a new section of un-touched or un-buffed paint.
Doing a second test spot in the same area will give you skewed results since you've already altered the paint in that spot with the products you tested.
Beginner question here:
I will be using a DA for the first time to remove moderate light to moderate swirls. I bought a 7424XP, orange and white LC flat pads, and Meguiars UC and UP. I know that we should always use the least aggressive method.
For my test spot I am thinking of starting with UP on a white pad. It this does not remove the swirls, then do a second (separate, as mentioned above) test spot with UC and an orange pad, followed by the UP/white pad combo.
Is this the right way to approach the situation?
derass
Yes but depending on your paint and what results you want to achieve, ultimate polish wont do much as far removing the swirls (depending on how bad it is) its very light in cut just make sure you do an alcohol wipedown or carpro eraser to inspect the true results.
Thank you so much mike!!! ;)
