Basic Hand Sanding Techniques
Soak your papers at least 15 minutes before use.
The Nikken Finishing papers have a latex rubber impregnated paper backing that is waterproof and this prevents the finishing paper from breaking-down into pulp from over soaking. I've personally soaked these paper in water for over 2 years with no visible sign of deterioration. (This was by accident as I lost a sealed Tupperware container filled with water and Nikken papers I used to take with me to demonstrations)
It's possible for grit particles to enter into your water source so if you can, use Grit Guards in the bottom of your bucket.
If you want to get really D.O., you can place your papers in dedicated buckets and also use dedicated backing pads for the different grits. The idea is to avoid instilling deeper scratches as you work upward to less aggressive products and to avoid any kind of abrasive particle trapped between your sandpaper and the finish to avoid Tracers.
Dedicated buckets for specific grits of paper. Grit Guard Inserts in the bottom of each bucket.
(You could theoretically use 2, even 3 Grit Guard inserts in each bucket for even more protection)
http://www.autogeekonline.net/galler...riment1002.jpg
Try to place your papers in water and soak them at least 15 minutes before sanding. I usually soak my papers overnight and sometimes a few days before sanding.
http://www.autogeekonline.net/galler...riment1003.jpg
Place different grit papers in their own dedicated water bucket
http://www.autogeekonline.net/galler...riment1004.jpg
Final sanding should be done with the highest quality grit particle size paper you can obtain. At this time with Nikken that's #3000 grit.
http://www.autogeekonline.net/galler...riment1005.jpg
Add just a few drops of a quality car wash soap to help add lubricity to your water. If you're working on Fresh Paint and/or in a Body Shop, (Fresh Paint Environment), then you want to make sure you're using a body shop safe soap.
http://www.autogeekonline.net/galler...riment1006.jpg
Add fresh, clean water. Also be sure to wash and rinse out your buckets before starting, everything must be surgically clean before placing your papers into the buckets.
http://www.autogeekonline.net/galler...riment1007.jpg
It's normal for your papers to roll up like this,
http://www.autogeekonline.net/galler...riment1008.jpg
http://www.autogeekonline.net/galler...riment1009.jpg
http://www.autogeekonline.net/galler...riment1010.jpg
Mark you buckets so you can quickly and easily identify which buckets hold which papers.
http://www.autogeekonline.net/galler...riment1011.jpg
There are two common ways to wrap your paper around a backing pad, my personal preference is to wrap each half-sheet around completely around the backing pad.
http://www.autogeekonline.net/galler...riment1025.jpg
http://www.autogeekonline.net/galler...riment1026.jpg
http://www.autogeekonline.net/galler...riment1027.jpg
One side is covered with a seamless portion of sandpaper. This of course is the side you sand with.
http://www.autogeekonline.net/galler...riment1028.jpg
Another option is to fold a single half-sheet of paper in half once and then fold this around your backing pad. Some people like this method better and there are some that say it's possible to put deeper scratches in the paint from the sides of the backing pad due to the way the paper will tend to bow. If you hold your backing pad at an angle when sanding this shouldn't be a problem but most people don't concentrate enough on the task-at-hand and sand with the backing pad perpendicular to the direction they are sanding or moving their hand. So if it can happen, then it might be an issue and I just wanted to point this out in an effort to be thorough.
Folding a sheet in half and wrapping it around a backing pad.
http://www.autogeekonline.net/galler...riment1039.jpg
http://www.autogeekonline.net/galler...riment1040.jpg
http://www.autogeekonline.net/galler...riment1041.jpg
http://www.autogeekonline.net/galler...riment1042.jpg
One side is completely covered, this if course is the side you sand with.
http://www.autogeekonline.net/galler...riment1043.jpg
Half sheet folded around the backing pad.
http://www.autogeekonline.net/galler...riment1044.jpg
http://www.autogeekonline.net/galler...riment1045.jpg
What it looks like from a top view.
http://www.autogeekonline.net/galler...riment1046.jpg
Each person should try both ways and decide for themselves which method works best for them. Also, finding a way to grip the backing pad and at the same time place equal pressure over the top surface of the backing pad is tricky. I find I have to grip the sides with a pinky and a thumb and then use my 3 middle fingers to apply pressure to the back face of the pad in order to sand without losing grip or control. Practice and find a way that works for you.
Next, use plenty of water from a clean source to lubricate the surface while sanding. Add a little soap, (a few drops is all that's needed, don't go crazy with the soap), and as you sand, continually spray water to the section you're sanding as this will make each stroke easier. Seriously, spray water onto the surface after every other stroke or two you'll find the paper will cut a lot smoother.
http://www.autogeekonline.net/galler...riment1029.jpg
Hold the backing pad canted, or at an angle, see how the tip of the paper-wrapped backing pad is leading as I move my hand forward. Don't hold the pad squared-up as you sand because you'll tend to cut deeper ruts if you sand with the pad in perfect perpendicular alignment in the direction of your strokes.
Right - Hold backing pad at a little bit of an angle while making front to back strokes.
http://www.autogeekonline.net/galler...riment1030.jpg
Wrong - Don't sand with the backing pad in a perpendicular alignment with your front to back strokes, you risk gouging or putting in deeper scratches where the paper is cutting on the outside edges of the length of the backing pad.
http://www.autogeekonline.net/galler...riment1038.jpg
Note the direction of my strokes and note the angle at which my pad is laying on the paint with one of the edges leading. This is correct backing pad alignment for hand sanding.
You should see paint residue in your sanding water
The white stuff in the water is clear paint particles that have been sanded off. If this were a single stage paint you would see the color of the pigment in the water.
http://www.autogeekonline.net/galler...riment1031.jpg
After
Close-ups with the overhead florescent tube light reflection on each section.
http://www.autogeekonline.net/galler...riment1033.jpg
Size of area to hand sand
The size of the area you want to sand comes down to two rules of thumb,
- 20" by 20"
- Let the panel be your guide
20" by 20"
For taking off the greatest portion of material you want to keep your work area to a manageable size of about 20" square or so... the reason for this is because,
- You want to carefully remove only the necessary amount of material
- You want to remove a uniform amount of material
While the above two listed items can read and sound like the same idea they are in fact different ideas.
1. Only remove the necessary material
Sanding removes paint and compounding removes paint, because you only have a limited amount of material or film-build to work with you only want to remove the minimum amount of paint to get the job done. An example would be removing Orange Peel. When removing orange peel you sand till the surface goes flat and then stop. There's no need to continue sanding after the surface goes flat as there is no more benefit, only loss of material, (material is the paint).
2. UMR = Uniform Material Removal
Since your sanding section by section, the ultimate goal will be to remove the same amount of material in a uniform manner over the entire panel and/or the entire car. This takes practice and concentration on the task at hand.
Back to the 20" by 20" size section...
Now let me explain how this ties into the size of area you sand. In the case of the general rule of thumb of sanding a section 20: by 20" the farther away from your body you move your hand, the more likely you'll exert less pressure than when your hand is closer to your body. So the longer your stroke, the more likely that you'll remove less paint the farther your hand moves away from your body. This makes for uneven material removal. It can also lead to removing too much material in the area closer to your body. By keeping your sanding area to a arm's manageable area you'll improve the likely hood that you'll only remove the necessary amount of material to get the job done and you'll remove material equally over the section your sanding.
"Let the panel be your guide"
http://www.autogeekonline.net/gallery/data/787/yoda.jpg
(When you read the above sentence, use your best Yoda impersonation)
You won't always be working on a perfectly square, flat hood, there are many places where you'll be sanding thin panels of paint like around the top portion of a fender, the A and B pillars, complex panels that make up the design of a body style that have raised or hard body lines. In these case you need to let the panel be our guide and this may mean sanding very small areas or areas that are longer than they are wide.
Here's an average size hood that I've taped off into 6 section which is how I would knock down or remove the majority of paint off this panel. After sanding the first section, all future sections would also overlap into the previous section(s) for good UMR.
http://www.autogeekonline.net/galler...AreatoSand.jpg
For the final sanding work I would larger section using higher grits as a way of tying all the sections together for even UMR. After wiping the hood clean and inspecting then I would compound the paint to remove the sanding marks.
This is just my way, please feel free to find your own way and if it's different than mine, please feel free to start your own thread documenting your approach with pictures and your explanation of your process.
Further Resourses
How long will a half sheet of wet/dry sandpaper last before it stops cutting and you need to replace it?
Wet-sanding - Fresh Paint vs Factory Paint
RIDS and Feathersanding - A Highly Specialized Technique by Mike Phillips
Removing Orange Peel & Sanding Marks with the Griot's ROP and the Wolfgang Twins
http://www.autogeekonline.net/forum/...lies/smile.gif
Re: Basic Hand Sanding Techniques
Awesome Mike!
Was wondering if you have any basic DA sanding techniques and How-to's. Would love to read on and probably try one day..:dblthumb2:
I didn't see those papers listed on the AG site, does AG sell them?
From my list of articles under Wet-Sanding, here's a brand new one...
How-To Articles
Wet-Sanding
Damp-Sanding Tools, Tips and Techniques by Mike Phillips
The video in the below link also shows dampsanding with a DA polisher briefly but the techniques shown and the arm speed are accurate.
Quote:
Originally Posted by
AeroCleanse
Here you go...
Meguiar's 6" Unigrit Sanding and Finishing Discs
List of Sanding Discs at Autogeek.net
Sanding Backing Pad
E7200 Meguiars Sanding Pad
I believe those are the Meguiar's sanding papers. I bought some previously and I think they had the Nikken label on the back. I have a HUGE order in my cart that I am finalizing that includes the damping sanding paper in varying grits and all of the DA damp sanding materials so I can damp sand with my 7424. Can't beat the prices for the Meguiars and then our discount.
Don
DonMTV
Don
Meguiar's owns the "distribution rights" to Nikken Finishing Papers in North America.
I know Bill Stuart personally, he's the gentleman who first obtained the distribution rights for these electronics grade papers and then sold them to Meguiar's.
Bill Stuart owns the "Absorber" and "Glosser" company and is one of the nicest people you will ever meet.
thanks for the great article. :xyxthumbs: i'm new to hand sanding/wet sanding and am trying to study it.
just a couple of questions:
how do you tell if the paint needs sanding or just compounding? (some scratches i can't get out using just a compound + pad combo)
how do you know if you've sanded enough?
:confused::confused:
blue DX
First... GREAT QUESTIONS!
Let me see if I can give you some answers that help...
blue DX
How to tell if the paint needs sanding or compounding depends upon what you're working on and what the goal is for the end results.
If you're working on a Daily Driver, then in my opinion, it's usually not a good idea to try to remove each and every single scratch out of the paint because since it's a daily driver it's going to get more scratches into the future and continually removing "all" of the scratches will continually remove more and more of your car's precious clear layer of paint and if it's the factory paint then it's thin to start with and you're probably going to be better off learning to live with the deeper scratches versus trying to remove them.
Here's an example, I just buffed out this car and I not only didn't try to remove all the deepest scratches I in fact didn't remove all the deepest scratches. I did however remove the zillions of shallow scratches and the effect is a show car finish that the owner loves.
1972 Challenger - Foam Pads - Meguiar's Microfiber Compound & Polish/Wax - Single Stage Black Paint
Before - Zillions of shallow scratches
http://www.autogeekonline.net/galler...llenger008.jpg
After - a very, very nice finish that was created safely
http://www.autogeekonline.net/galler...lenger0221.jpg
Removing the zillions of light or shallow scratches will have a dramatic effect on how the paint looks, so dramatic that it will still have a "Show Car Look" and that's usually enough to make most people happy whether it's you're own car or a customer's car.
See this article on the topic of random, isolated deeper scratches as it explains a lot of this topic...
If you're working on a show car then while it's important to try to remove as many of the defects as possible you are still limited by the thickness or film-build of the clear layer of paint or the colored layer of paint if you're working on a single stage paint.
The last thing you want to do is to remove so much paint on a show car that you have to pay to have it repainted. That's not going to be any fun.
So first, determine what your goal is and take into account the type of car you're working on, daily driver or show car. Then use the least aggressive approach to remove the defect or improve the defect to the point that it's less noticeable and you or your customer can live with it.
"Use the least aggressive product to get the job done"
As for sanding or compounding, sanding with the right papers or discs can enable you to remove defects without generating the heat associated with using a rotary buffer but if you use a rotary buffer with good technique you can remove defects without sanding safely. It's just a matter of being careful.
Instead of writing more on this topic, here are some articles that address it...
You have to weed through this article to find it but somewhere in here is a paragraph that states why sanding can be safer then just compounding...
This article can teach you how to use a rotary buffer carefully when only buffing out isolated defects, the point being that you have to be conscience of the surface temp as you're buffing and sometimes you may have to buff a little then stop and let the paint cool down, then buff a little, then let the paint cool down. I can go deep as to why but read the article and see if that does it for you...
Fight or Flight Method for Gaging Surface Temperature
Here's one that explains RIDS
RIDS - The Definition of RIDS and the story behind the term...
Here's one on removing RIDS
blue DX
Experience and focusing on the task at hand.
Remember... sanding removes a little paint and so will your compounding and polishing steps, so sometimes you can sand most of the defect out but not all of it and then when you compound the sanding marks out you'll remove enough paint to remove your sanding marks and the rest of the defect.
Definitely read this article...
Next...
What are you working on?
