Wolfgang Uber Spray Coating & Uber Sio2 Rinseless Wash
Hi
What else could I use as toppers and to maintain the uber spray coating, my thoughts are:
- Sio2 Silica Spray
- Sio2 Sealant
- Sio2 Rinseless Wash (used as waterless)
Any further thoughts or is this a overkill?
Thanks in advance
Re: Wolfgang Uber Spray Coating & Uber Sio2 Rinseless Wash
Quote:
Originally Posted by
PeteT19640
Hi
- Sio2 Silica Spray
- Sio2 Sealant
Thanks in advance
Any sio2 based from most manufacturers should work.
If wanting to keep synergy i would use WG silica spray every 2-3 months and maintain with Uber sio2 rinseless.
PeteT19640
Hi
See what I share here,
When it's on SALE - GETS SOME! - Wolfgang Uber SiO2 Coating Wash
:buffing:
Coatingsarecrack
Thanks would like to keep to the Synergy.
Leave out the sio2 sealant?
Mike Phillips
Thanks Mike
Can it be used in a foam gun?
PeteT19640
Using both the sealant and silica spray would be kinda redundant but hey i’ve layered more. If you wanna use it go ahead but not needed
PeteT19640
Thanks Mike
From what i’ve understood is yes but doesn’t foam well.
PeteT19640
Thanks Mike
I can be but it will NOT make suds.
Just wash how I show here,
How to safely wash a ceramic coated car by Mike Phillips - Traditional Hose & Bucket Approach
I wasn't sure if I was doing right but I mixed WF SIO2 waterless wash and Bk SIO2 spray sealant....I am no expert but to me it worked fine...easy on and off
Coatingsarecrack
Ok thanks
Having it in the foam gun would be great and water blast it off, then do the waterless wash after that.
Thank you
