Overheating griot's polsher
Did anyone have a problem with the griot's buffer overheating. It seems like after using it 2 days in a row it overheats and eventually shuts off.
Re: Overheating griot's polsher
Never had that problem. Call Griot's customer service--they are very helpful.
I just recently had an issue with my GG6 (loose spindle). I contacted Griots directly and they gave me a warranty sheet to fill out and I mailed it back to them and a week later I had a brand new GG6.
if you haven't already, try using a thicker gauge cord and if the problem still persists, call griots and they should take care of you...
OP, is this your first time using a DA?
If so, the overheating may be related to some user error. Heat is a byproduct of the friction during the polishing process. While the motor of the polisher creates some heat, most "overheating" problems start at the pad, and travel through the backing plate - through the spindle mechanism into the machine.
Some things that make a polisher run too hot:
1. Using too much buffing liquid
2. Using too much downward pressure.
3. Running at top speed with significant downward pressure for significant intervals.
I wouldn't be so quick to blame it on the cord. All you have to do to rule out if an extension cord is a problem is feel the temperature of the cord. If the cord is quite hot - that could be a sign the cord is an issue.
That being said, me and like a zillion others have used the GG6 with whatever orange extension cord I've had laying around and never have had an issue. Hopefully your not using an inside extension cord, but if your using an outdoor style one you are like good unless it's defective or damaged.
4. BP rubbing on the shroud.
5. Operating the machine at very high ambient temperatures.
By wcharon in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 11-16-2020, 09:43 PM
By Jomax in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 09-06-2016, 04:15 PM
By duffthebluff in forum Flex Polishers
Last Post: 04-21-2015, 12:04 AM
By b0b in forum Ask your detailing questions!
Last Post: 11-27-2013, 01:36 PM
By Donnym in forum Product Reviews
Last Post: 06-30-2010, 02:40 PM
26 | 27 | 28 | 29 | 30 | 31 |
